Router Table Box joint jig
Forum topic by EdsCustomWoodCrafts posted 10-06-2015 06:39 PM 1583 views 0 times favorited 7 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
766 posts in 1307 days
10-06-2015 06:39 PM
Hi everyone
I have a question.. I want to build a jig and I even went and bought some 5.5” wide boards .. But my router table is shop built and I have no mitre slot in it..
My plan was to build this using a 1.5” thick poplar board as a fence and put a 1/2” sq dowel as a key and then putting another slot 1/2” sq to position the stock I’m cutting
But I never figured on how to keep the jig straight on the table..
Any suggestions!!!!!
Below is what I’m thinking of building but 12” wide
http://lumberjocks.com/assets/pictures/projects/185108.jpg
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
7 replies so far
View David's profile
David
74 posts in 1991 days
#1 posted 10-06-2015 06:47 PM
Make your jig hang over the edge of the router table and place a cleat on the bottom side of the jig (use clamps to make it removable) the cleat will run along the table face , which will give you a strait edge to keep the jig strait
-- http://littleredshop.net "A man that works with his hands, knows his soul" " Have Fun, Go Fast, and Take Chances for Christ's Sake!!"
View HokieKen's profile
HokieKen
4736 posts in 1102 days
#2 posted 10-06-2015 07:22 PM
Or build the jig fence “L” shaped and ride the edge on your router fence. David’s way is a good way, but I’m not sure I’d trust the edging on my table to be flat enough. I know my fence is flat though.
-- Kenny, SW VA, Go Hokies!!!
View Redoak49's profile
Redoak49
3193 posts in 1952 days
#3 posted 10-06-2015 08:24 PM
Another issue to consider is that the 1/2” square stock may not be accurate enough. It needs to be extremely close to the size of the slot the router bit cuts.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3250 days
#4 posted 10-06-2015 08:34 PM
You can easily add miter track to your router table if the top is thick enough. Simply route out for the track and screw it in.
Check this out.
http://www.rockler.com/rockler-36-miter-track
I have it in two router tables I built and use it all the time.
-- http://shepherdtoolandsupply.com/
View Fuzzy's profile
Fuzzy
298 posts in 3952 days
#5 posted 10-06-2015 11:03 PM
This is about the most simple jig I’ve ever used on a router table. Make it from scraps … it’ll work just fine. Make it from better material for longevity. Easy to build to suit your router table setup.
http://www.routerworkshop.com/boxjoints.html
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View KnickKnack's profile
KnickKnack
1088 posts in 3530 days
#6 posted 10-07-2015 11:48 AM
Rather than building a specific box joint jig, you might consider building a “precise movement jig”.
I believe I’ve seen these commercially available, but it’s super-easy to make one yourself – all you need are two long “bolt” rods with a known thread pitch.
I wrote a little blog about mine many years ago here – that “proof” of concept thing is what I still use today.
I use 1mm pitch bolts – so one complete turn is 1mm – if I want 5mm box joints that’s just 10 turns to move my piece exactly 10mm.
It’s what I used for this and this and this – well – all the things I make that need precise spacing.
It’s much more general purpose than just box joints of a given size – box joints of any size – joints with different sizes – sets of slots.
Just an idea.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
EdsCustomWoodCrafts
#7 posted 10-07-2015 08:29 PM
- David
Hi David I’m wondering should the cleat be 1” wide so as to accommodate the 1/2” key and then a 1/2” slot
