Looking for a little help with end grain cutting board
Forum topic by JimTsia posted 10-06-2015 02:30 AM 672 views 0 times favorited 5 replies Add to Favorites Watch
View JimTsia's profile
JimTsia
1 post in 2481 days
10-06-2015 02:30 AM
I have been working on my first end grain cutting board. Cut my strips, glued them up, cut them again, glued them together. Now I have my end grain cutting board ready to finish off. Start to run it through the planner to smooth out the top and bottom and during the first pass the cutting board breaks off the the last couple of inches.
Am I doing something wrong? Clearly, I have, but looking to figure out what. Any advise would be helpful as I had put a large cutting board together and would like to be able to salvage something from what I have done.
Thanks,
Jim
5 replies so far
View kurtsr's profile
kurtsr
6 posts in 1419 days
#1 posted 10-06-2015 02:35 AM
Dont run endgrain thru the planer Use a thicknes sander or a router sled
View BurlyBob's profile
BurlyBob
6030 posts in 2500 days
#2 posted 10-06-2015 02:38 AM
Kurt’s right on the money!
View Betsy's profile
Betsy
3392 posts in 4131 days
#3 posted 10-06-2015 02:46 AM
In all likelihood you tried to take too large of a cut. If you run an end grain broad through the planer you absolutely must take tiny little bites. I run all of my boards through the planer with no issues – it’s a hot button topic – but I do it all the time and have had no problems. Perhaps I’m running on borrowed time – but I just cranked out 220+ end grain boards (Christmas season shows) and every last one went through the planer.
The trick is to have a good glue up technique and take small cuts. it also helps to use a scrap piece on both ends of the board so any tear out will be on scrap that can be cut away.
Takes patience to do it without having a blow out. But if your glue up is clean – as in not a rocky top – but even you can do it.
Just my take on it – not saying it’s for everyone – but works for me.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
View nerdbot's profile
nerdbot
97 posts in 1596 days
#4 posted 10-06-2015 03:38 AM
I also run my end grain cutting boards through the planer, but I take very light passes and I stand off to the side. I will say that it’s very hard on the blades in my planer. Did you chamfer the back edge? If I don’t do that, I get a ton of tear out on the back edge.
Betsy
#5 posted 10-06-2015 03:43 AM
Glue a sacrificial piece of pine on each end of the board before planning. Any tear out will be in sacrificial piece and all you have to do is cut those pieces off and good to go. Just remember very small passes and you’ll be okay. I also, like nerdbot stand to the side, but that’s just good practice with most any tool with spinning blades.
