Building a table - confused by instructions
Forum topic by Andrew S. posted 10-06-2015 02:19 AM 628 views 0 times favorited 2 replies Add to Favorites Watch
View Andrew S.'s profile
Andrew S.
6 posts in 839 days
10-06-2015 02:19 AM
Topic tags/keywords: question
Hi everyone,
I’m new to this, both the forum and woodworking. I’ve built a bookcase (floor to ceiling with diamond shaped cubbies), but that’s it.
I’ve decided to build this table: http://www.thisoldhouse.com/toh/how-to/intro/0,,20438427,00.html
The wood isn’t cheap, so I don’t want to experiment and ruin it. I’m starting slow, and I’m on Step 3 (http://www.thisoldhouse.com/toh/how-to/step/0,,20438427_20870497,00.html), but I’m a little confused and I’m hoping someone with more experience could shed some light.
The instructions indicate to “[drive] 3-inch deck screws through the top corners of the corbel and into the post’. I’m not sure what they mean by the “top cornes of the corbel”.
Also, once I’ve done the 5/8” hole in the corbel at a 45 degree angle, and I put the 3/8” lag screw in will I be able to sink the lag screw in far enough that it isn’t protruding from the bottom?
Sorry for the stupid questions, but as I said, I don’t want to ruin the wood with experimenting because of vague instructions. I do have some extra wood at home to experiment on, but I’m hoping for some tips.
Thanks!
2 replies so far
View rg33's profile
rg33
83 posts in 1876 days
#1 posted 10-06-2015 05:27 AM
Youre just putting 3” screws in the corners. Take a look at step 5 photo, it shows the 3” screws on the corners.
I may be wrong but I think they omitted a step. The 5/8” hole with a spade bit is simply acting as a counterbore for the lag screw (if you dont know what a counterbore is, do a quick google search). Where I think they missed a step is that on that counterbore you need to drill a smaller clearance hole for the lag screw. You should counterbore deep enough with the spade bit so that enough of the lagscrew protrudes out and screws into the post.
Andrew S.
6 posts in 839 days
#2 posted 11-22-2015 02:59 PM
Thanks for the advice rg33!
I stumbled through the rest of their instructions and ended up with a table! It’s not level, but it is pretty darn close and I’m proud of it for my first table.
I will say they didn’t discuss dimensions well in the instructions so i winged it. I ended up leaving the 4×8 sheet of plywood intact for the table top, and that is kind of large for a table.
