Replacing the bearings on my Carter bandsaw guides.
Forum topic by jobewan posted 10-05-2015 11:07 PM 474 views 0 times favorited 1 reply Add to Favorites Watch
View jobewan's profile
jobewan
33 posts in 943 days
10-05-2015 11:07 PM
Hey Folks,
For reasons I won’t go into I had let my WW equipment sit for more than 12 years. I am getting back into it now, and I am currently rejuvenating my bandsaw. I have replaced the tires, checked the wheel bearings, replaced the blades (they all had more corrosion than I wanted to deal with on them) and the last thing I need to do is replace the bearings on my ball-bearing guides. They just don’t spin as fluidly as Id like.
So I bought a new set of bearings – quite cheap – I guess this is a very common bearing. So my question, never having done this, is how to get the bearings swapped out. What is the easiest way to remove the old and then press in the new bearings? Anyone have any suggestions?
I really appreciate any help you may be able to throw my way. Thanks in advance
Joe
-- Measure Twice, Cut Once - throw it in the woodpile, start over...
1 reply so far
View MrUnix's profile
MrUnix
6592 posts in 2165 days
#1 posted 10-05-2015 11:23 PM
Don’t know what carter set you have, but the bearings should not be a press fit. There should be a hex head bolt or cap screw that you remove first, then the bearings should just slip off.
