Reassembly after pocket holes
Forum topic by CudaDude posted 10-05-2015 07:04 PM 717 views 0 times favorited 5 replies Add to Favorites Watch
View CudaDude's profile
CudaDude
179 posts in 2302 days
10-05-2015 07:04 PM
Does reassembly using existing pocket holes weaken the joint, or will the screws grab the threads that are already in the wood and create a tight joint? It will be glued also. Thanks
-- Gary
5 replies so far
View Shane's profile
Shane
294 posts in 1805 days
#1 posted 10-05-2015 07:07 PM
I would think it should be fine. Especially if you are going to add glue.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1569 days
#2 posted 10-06-2015 02:02 AM
I’ve done it,just make sure the joint is tight before you re-screw or you ream the old threads out.
View POGO's profile
POGO
19 posts in 2879 days
#3 posted 10-09-2015 12:16 AM
If you are asking about using the same holes created before final glue-up Yes and No depending on type of wood product. If you are using hardwood, don’t seat the pocket screw fully and you should have no problem reusing the hole during final glue-up. Plywood is a different animal and in most cases will not allow for re-use of the pocket hole.
I use pocket holes to augment clamps to keep the glue-up process moving. I dot not rely on pocket holes only for keeping joints tight.
-- Arvid, Spring Texas
View rwe2156's profile
rwe2156
2920 posts in 1475 days
#4 posted 10-09-2015 11:01 AM
I would think you should be fine but like poster said, depends on wood type.
I don’t like them in plywood and I think this will give you the most trouble rescrewing.
Also +1 on pocket screws = clamps, not permanent joint without glue.
Even when glued, you are usually looking at end grain gluing which is weak.
They have been proven over and over to be one of the weakest joints so always consider use of piece before opting for this type of joinery.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2364 days
#5 posted 10-09-2015 01:02 PM
I’ve done it often with both ply and solid wood. If you’re using a good quality ply, you won’t have problems. On the initial assembly, I never tighten the screws all the way down. Get them just barely snug, and then on the final go-around, tighten them all the way. As others have said, use clamps during both assemblies, and add glue during final assembly (although I’ve done plenty of times without glue, and those haven’t failed yet).
