Joint Question
Forum topic by Stickler posted 12-02-2009 10:23 PM 1186 views 0 times favorited 7 replies Add to Favorites Watch
View Stickler's profile
Stickler
4 posts in 3240 days
12-02-2009 10:23 PM
Topic tags/keywords: question oak joining arts and crafts
I’m building a replica of a 1904 Stickley Cheval (standing) mirror. I have pictures of examples, but no plans. It’s all pretty straightforward with one exception. The stand for the mirror is a wishbone design. I can’t for the life of me tell how Stickley attached the two legs (per side) together. The figure shows the original piece and three ideas I have for joining the legs. Which would you go with? Or is there something obvious I’m missing. BTW, the top right would be mortised, not a butt joint. The split sides (bottom right) would be biscuited. Only the bottom left would be a straight glue up.
Joinery question
7 replies so far
13630 posts in 3484 days
#1 posted 12-02-2009 10:33 PM
i would suggest a scarf joint ( google it ) ,
like in the second one ,
but with the legs coming out the side of the top ,
not the bottom of a full center piece .
View bfd's profile
bfd
502 posts in 3950 days
#2 posted 12-02-2009 10:48 PM
I think the best bet is bottom right. if your stock is thick enough you can cut the shape on the bandsaw and then resaw to get two identical legs that will be bookmatched.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3623 days
#3 posted 12-02-2009 11:19 PM
I agree with Brian. I think it would be the strongest using the joint on the lower right.
-- Wayne - Plymouth MN
View Brian Havens's profile
Brian Havens
196 posts in 3249 days
#4 posted 12-03-2009 12:12 AM
Another vote for the bottom right, with the argument that there is plenty of long-grain to long-grain on the glue joint, which means glue alone will be plenty strong. I also like (the other) Brian’s bookmatching idea.
-- Brian Havens, Woodworker http://brianhavens.com
#5 posted 12-03-2009 02:40 AM
i like the book match idea too ,
was just concerned about the
use of 8/4 stock to curve and resaw ,
if you have the wood ,
it would be the strongest ,
and the nicest to look at .
Stickler
#6 posted 12-04-2009 10:00 PM
Thanks everyone for the advice. I decided on the bottom right and have put in an order with Talarico to get the 12/4 qtrd oak stock I need to bookmatch the pieces. Wish me luck—those legs are going to be pricey.
View MedicKen's profile
MedicKen
1615 posts in 3605 days
#7 posted 12-04-2009 10:08 PM
Here is another option.http://lumberjocks.com/projects/24079
