The best way to machine for slot or barbed hinges?
Forum topic by fineamerican posted 12-02-2009 08:27 PM 11872 views 1 time favorited 24 replies Add to Favorites Watch
View fineamerican's profile
fineamerican
150 posts in 3232 days
12-02-2009 08:27 PM
Topic tags/keywords: tip
Hi everyone Im curious to find out the best way to install these hinges in boxes. Ive tried with a drill press but have had varied results. In a book written by Doug Stowe he uses a router table. Im just curious to see what a majority thinks and if someone has a tip Im all ears!
Thanks!
John
-- John A. Thomas, South Carolina, www.thomaswoodworker.com
24 replies so far
View MedicKen's profile
MedicKen
1615 posts in 3579 days
#1 posted 12-02-2009 08:42 PM
Are you talking about the hinges that look like biscuits?
fineamerican
#2 posted 12-02-2009 08:49 PM
yes those are the ones
MedicKen
#3 posted 12-02-2009 09:31 PM
Biscuit joiner or a 3/32” slot cutter in the router table.
View OhValleyWoodandWool's profile
OhValleyWoodandWool
970 posts in 3238 days
#4 posted 12-02-2009 09:53 PM
I’ve been curious about this as well process as well but I think that Ken’s ideas would cut a slot that is much too big. From what I’ve been able to determine the drill press is the way to go but you have to come up with a jig that aligns everything. I’ve heard about the router table idea but the blades that cut the slots really aren’t engineered for that level of torque. Even if the router is slowed way down I’m afraid that the blade would come apart with the results resemble shrapnel much too closely. I too would love to hear how other jocks have accomplished this.
-- "All you need in this life is ignorance and confidence, and then Success is sure." Mark Twain
13625 posts in 3458 days
#5 posted 12-02-2009 10:16 PM
i have some i used for small boxes ,
you need the slot saw that is made for them ,
it is t shaped ,
and mounts in the router .
i did mine in the router table ,
and carefully marked the edge of the fence ,
as the top and bottom are right and left to each other
as they come out .
once they are in ,
forget taking them out ,
do your finishing first , unless its oil
fineamerican
#6 posted 12-02-2009 11:07 PM
I agree, I think the biscuit kerfs would be too big.
Patron thanks for your advice
View Kindlingmaker's profile
Kindlingmaker
2657 posts in 3644 days
#7 posted 12-03-2009 12:40 AM
There are some very interesting Dremel blades available…
MedicKen
#8 posted 12-04-2009 08:04 PM
I was thinking of a different type of hinge. I agree the standard cutter on a biscuit joiner would be too large. i found this at Woodcraft.
View Blake's profile
Blake
3443 posts in 3991 days
#9 posted 12-04-2009 08:40 PM
Yes that saw blade and arbor is pretty much the only way to go.
Its a little pricey, especially to get both blades. But I found it to be a really good investment because I also use the blade to cut micro-keys in mitered boxes and frames like this one:
Click for details
I just put the mini saw in my router table (you MUST have a variable-speed router) and set my miter gauge to 45 deg with a stop block, and run the corners of my box/frame through the blade.
-- Happy woodworking!
View WayneC's profile
WayneC
13770 posts in 4214 days
#10 posted 12-04-2009 08:44 PM
Do you run it at lowest speed? Looks like it was designed for a drill press.
#11 posted 12-04-2009 08:52 PM
i just looked at mine ,
it is a one piece that is flush across the top,
no nut or allen screw .
i can’t see any company name on it ,
but im still trying to find it on-line .
it was way cheaper than the one at woodcraft ,
and i know i just used the router table for mine .
i’ll keep looking .
Blake
#12 posted 12-04-2009 08:58 PM
Yes, lowest speed possible on your router and slow feed rate.
And to answer the original question (I may have read it wrong the first time) I cut the hinge slots on my router table with a simple “sled” that allows the box to “feed” straight into the blade. I also clamp stops in place to get consistent results and not cut too deep. The sled is just a thin rectangle of hardboard with a runner that fits in my router table’s miter slot.
Plunge a little at a time into the blade (in and out) until you hit your stop block. This will keep the blade from bogging down or overheating.
I tried setting up a jig for the drill press (they even include plans for it with the blade) but I hated it. It didn’t seem accurate enough for such fine hinges.
View reggiek's profile
reggiek
2240 posts in 3387 days
#13 posted 12-04-2009 09:02 PM
I was wondering if perhaps you could use one of the dial a slot cutter bits for a router? I haven’t looked at the specs…but it seems that you could adjust the size to fit (I have one with micro shims that I use to cut splines in very small boxes….I use it to make a slotted mortise and tenon joint for turned spindles and for cutting decorative slots in turned items…)...I also like the idea of using the dremel…I don’t think I could ever give up my dremel…it is just to useful…
Blake
#14 posted 12-04-2009 09:09 PM
Yes. I use it in my router (read my post above). But it MUST be variable speed.
#15 posted 12-04-2009 09:28 PM
i’m still looking !
