Thickness planer accuracy/tolerance troubles...
Forum topic by roha2236 posted 10-05-2015 03:03 PM 1698 views 0 times favorited 12 replies Add to Favorites Watch
View roha2236's profile
roha2236
42 posts in 990 days
10-05-2015 03:03 PM
I recently bought a used Delta DC380 planer and spent a fair bit of time tuning and setting it up before running anything through it. Took forever to get the head casting parallel to the bed, but I’m pleased to say it’s within 0.001”. Long story short, there is, in my opinion, far too much variance from one end of the board to the other (front to back)...over a distance of 24”. Up to 0.02”! There’s a bit of a difference left to right (up to 0.005”), which I’m sure I can fix by adjusting the knives more. What I don’t understand is what would cause the front to back variance (in order to make the correct adjustments to fix the problem).
Any thoughts?
-- Roman
12 replies so far
View Stevedore's profile
Stevedore
72 posts in 2050 days
#1 posted 10-05-2015 06:22 PM
I’m not familiar with that model, so I’m just guessing, but is whatever carriage lock it has not holding securely? Maybe letting the head rise a bit due to vibration? (assuming the board gets gradually thicker as it goes through)
-- Steve, in Morris County, NJ
View nicksmurf111's profile
nicksmurf111
367 posts in 1475 days
#2 posted 10-05-2015 07:29 PM
Snipe. Adjust the infeed and outfeed roller tension . Adjust the infeed and outfeed tables. Make sure the bed is waxed. I think the outfeed table generally needs to rise by a tiny, tiny bit to tension the board against the outfeed roller. If the board you are feeding through isn’t jointed, it’s not sitting flat against the bed and that can cause issues also.
I have a Belsaw, but the Deltas have more adjustments there. I guess you can adjust the height of the infeed and outfeed rollers, the tension, AND the table rollers. I’d refer to the manual, using a dial indicator or feeler gauges, set all those height adjustments.
-- Nicholas
View Ocelot's profile
Ocelot
1980 posts in 2663 days
#3 posted 10-05-2015 07:34 PM
^ what nick sed. Board must be jointed.
roha2236
#4 posted 10-05-2015 10:14 PM
Thanks for the replies. The board was jointed before planing, and at first my calipers were still showing a difference in thickness even beyond the section of the board affected by snipe. After taking out my trusty One Way Multigauge and checking the bed rollers, I noticed that they went out of calibration. I adjusted them to 0.001” above the table, and the issue now seems to be rectified. I had also previously loosened the tension on the infeed roller because it was leaving significant marks when I planed at the slower feed speed.
-- Roman
View RogerM's profile
RogerM
792 posts in 2424 days
#5 posted 10-05-2015 10:32 PM
roha -
I have the DC380 also and love it. Like yourself, after some careful calibration efforts it offers really superior performance. One additional tip, consider purchasing a digital planer gage from Wiley http://wixey.com/planer/index.html. It takes a little effort to mount it but makes a totally different machine of the planer. Repeatable accuracy to .001 inch is a vast improvement.
-- Roger M, Aiken, SC
Ocelot
#6 posted 10-06-2015 06:21 PM
I have the wixey digital gauge on my planer also. I would order another one in a minute if that one was broken. I wouldn’t say I get repeatable accuracy to the thousandth, but it’s within 5 thousandths.
roha2236
#7 posted 10-06-2015 06:27 PM
I looked at the website for the Wixey and I don’t really see what it offers over my Mitutoyo digital calipers and One Way Milti Gauge. I creep up to my required thickness when planing, and can get good accuracy. Could someone who has the Wixey please explain the benefits?
-- Roman
4999 posts in 2518 days
#8 posted 10-06-2015 07:49 PM
I have a Wixey on my DC380, and use it to not only control the wood thickness when I’m planing, but to plane other boards to the same thickness. To explain, if I have some face frame wood and need more, I measure what I have with my digital calipers, then plane to that number with the Wixey. Works very well, though I check the accuracy every month or so with those same calipers. If it needs recalibrated, that’s about a 5 minute job. When I’m planing boards to 3/4” or whatever, I’m not constantly stopping to measure the board as I go.
RogerM
#9 posted 10-06-2015 08:11 PM
roha/Fred -
To calibrate the Wixley, run a board through the planer then raise the vertical measuring bar and place the board between the end of the bar and the lower mechanism of the gage. Remove the board and lower the measuring bar and you are calibrated. Takes less than 30 seconds.
This technique can be viewed at http://www.wixey.com/planer/how/calibration.html
RogerM
#10 posted 10-06-2015 09:34 PM
Wixley planer gage benefits :
Very accurate
Instant thickness readings
Repeatable thickness settings
Easy calibration
Fewer measurements – less chance for error
Considerable savings in time.
Eliminates “creeping up to required thickness” efforts
View Holbs's profile
Holbs
1878 posts in 2054 days
#11 posted 10-07-2015 12:45 AM
is it a constant 0.005” difference, on different species? I nailed my Jet 15” planer down to 0.001”-0.002” for beds, rollers, blades, etc. If something comes out 0.005”, I would suspect greater density of the wood piece at one end or something scientific like that. But really, does 0.005” on a piece of wood make that much of a difference in the end?
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
RogerM
#12 posted 10-07-2015 01:30 PM
No!, .005” makes virtually no difference at all. This is getting down to the thickness of a sheet of paper.
