Hand held reamer
Forum topic by Padre posted 12-02-2009 03:46 AM 1292 views 0 times favorited 5 replies Add to Favorites Watch
View Padre's profile
Padre
930 posts in 3725 days
12-02-2009 03:46 AM
I am going to be building a simple 4 legged stool, and I came across a plan, but it calls for a ‘hand reamer’ to make a hole in the seat that is narrower on the inside than and wider on the outside. I found some reamers on line for a hand brace, but I don’t have one. Any ideas?
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
5 replies so far
TopamaxSurvivor
18423 posts in 3912 days
#1 posted 12-02-2009 04:31 AM
You could probably make one with a steel blade clamped in a dowel. Drill the hole close to size on the angle then, ream it to finish size.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3343 days
#2 posted 12-02-2009 09:39 AM
Try the internet under “bridge reamner” and also check Lawson Products. See if you can find the degree of taper as they come in varying tapers. Good luck.
Padre
#3 posted 12-02-2009 08:06 PM
Thank you!!
View LesB's profile
LesB
1916 posts in 3679 days
#4 posted 12-02-2009 08:16 PM
You could use a straight sided hole and saw a split or slot in the tenon of the leg to accept a tapered wedge which would tighten the tenon in the hole as you drive it in. Like the wedge in a hammer or ax handle. If the mortise is all the way through the seat you can put the wedge in from the top. If it is blind you can start a smaller wedge in just before you insert the tenon into the hole. As you pound the leg in the wedge will bottom out and move into the slot. Watch the wood grain to avoid splitting as the wedge is driven home.
Check garage sales and flea markets for drill braces. There are always some there at a cheap price.
-- Les B, Oregon
View Kindlingmaker's profile
Kindlingmaker
2658 posts in 3762 days
#5 posted 12-02-2009 11:14 PM
This is a bit unorthidox…but… Rent a pipe reamer from your local rental yard…
