Is this a stupid idea
Forum topic by Zuki posted 12-02-2009 12:32 AM 1419 views 0 times favorited 18 replies Add to Favorites Watch
View Zuki's profile
Zuki
1404 posts in 3985 days
12-02-2009 12:32 AM
Topic tags/keywords: zuki stupid
Not stupid as in good, but stupid in the traditional meaning.
I have a bunch of 2×2x1 pieces of poplar that I want to use to make Christmas ornaments. 1 inch thick is a little big so I was going to rip them into ½ inch thick pieces. Now . . . to eliminate the BS waves and thin the pieces a little more I could
1) use a sander and make lots of dust or
2) take some 2 sided tape and tape all the pieces to a flat piece of board and run it through my planer a couple of times.
My gut is telling me that option 1 is the better (and safer) option, however option 2 does seem tempting and much quicker.
Is my gut right in telling me option 2 is a really stupid option?
-- BLOG - http://www.colorfulcanary.com/search/label/Zuki
18 replies so far
View hairy's profile
hairy
2608 posts in 3441 days
#1 posted 12-02-2009 12:38 AM
Maybe you could resaw on a tablesaw? 2 inches tall should not be a problem. You should end up with 7/16 inch thick boards, assuming a 1/8 inch blade.
That might be another stupid idea, but with a jig to hold small pieces, it might work.
-- My reality check bounced...
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3435 days
#2 posted 12-02-2009 12:53 AM
Do you have a dovetail saw, Dosuki or something like that? They cut very fast, clean and with very thin kerfs…
View Dan'um Style's profile
Dan'um Style
14171 posts in 3891 days
#3 posted 12-02-2009 01:04 AM
train wreck … for the double sided tape. I know cause I wrecked a train before
View RedShirt013's profile
RedShirt013
219 posts in 3570 days
#4 posted 12-02-2009 01:05 AM
The distance between the planer infeed roller, cutterhead, and outfeed roller is probably more than 2”. Double sided tape alone is not going to hold that little square down when the knife hits it. May end up having that piece kicked around inside your planer. I’d just sand it after resawing.
-- Ed
View Russel's profile
Russel
2199 posts in 3847 days
#5 posted 12-02-2009 01:21 AM
I’m going with option 1, and possibly double stick tape to hold the pieces while you sand them. Option 2 scares the daylights out of me (and I’m really afraid of the dark).
16272 posts in 4127 days
#6 posted 12-02-2009 02:07 AM
How to turn your planer into a grenade launcher. :-)
View WayneC's profile
WayneC
13751 posts in 4006 days
#7 posted 12-02-2009 02:17 AM
Sharp handplane for the win…..
Dan'um Style
#8 posted 12-02-2009 02:32 AM
jig is the best idea
View reggiek's profile
reggiek
2240 posts in 3178 days
#9 posted 12-02-2009 02:39 AM
That tape will gum up your planer and could be very dangerous (not to mention possibly destroying your planning knives or cutter)....I think everyone agrees on that…..I have the forrest WW II in my table saw and after ripping…I hardly need to sand….I would say…put them through the TS and wallah….maybe a quick hand sanding…..I only use the band saw on thicker stock (over the size of the blade) or for cutting very thin material…..
View Zuki's profile
Zuki
#10 posted 12-02-2009 02:52 AM
LOL . . . grenade launcher. I can see it now . . . square wooden hockey pucks flying all over the shop, taking out the lights one by one, knocking everything off the shelves with me huddling behind the bench. Really stupid idea.
I forgot about my Dosuki. I’ll give that a try and then the TS jig idea.
I think from now on I’m gonna leave my stupid ideas for work. :-)
Tks guys
WayneC
#11 posted 12-02-2009 02:58 AM
Expanding on my some what cryptic post above, rip them with the bandsaw and use the handplane to remove the waves… Skarp has a good suggestion that would get consistent sized pieces.
Dan'um Style
#12 posted 12-02-2009 03:18 AM
I think you should carve little angels on them and post them on lumberjocks in the project section …that’s my vote! what-da-ya-say? Zuki !!! <grin>
View yarydoc's profile
yarydoc
417 posts in 3053 days
#13 posted 12-02-2009 07:54 AM
(3) Use longer wood that won’t be dangerous to work with and then cut to the length you need. It could make the hollidays more enjoyable. I have a rule, if I wonder if its safe to do then its not.
-- Ray , Florence Alabama
View spud72's profile
spud72
324 posts in 3402 days
#14 posted 12-02-2009 01:03 PM
Instructions for Option 2:
you will need a ten foot pole and running shoes.
install running shoes on to feet,
place work into planner,
hit on switch with ten foot pole,
run like hell!
-- Guy,PEI
View PeteMoss's profile
PeteMoss
207 posts in 3379 days
#15 posted 12-02-2009 05:23 PM
I don’t know the correct answer, but I know from experience that a little chunk of wood loose inside you planer is a bad thing. I’m actually on my second planer now because of a loose piece of 3/4” x 3/4” x 2” hard maple. No, it wasn’t loose to start with, but when the knives hit it, all bets are off.
-- "Never measure......cut as many times as necessary." - PeteMoss
