Forum topic by nmssis | posted 10-04-2015 05:38 PM | 1215 views | 0 times favorited | 33 replies | ![]() |
Again to the experts…is this salvageable? Was thinking of building up wood fillers but…thought I’d ask the experts here. Thanks! -- Learn something new everyday! |
33 replies so far
#1 posted 10-04-2015 05:47 PM |
Picture problems -- Shooting down the walls of heartache. Bang bang. I am. The warrior. |
#2 posted 10-04-2015 05:53 PM |
thanks -- Learn something new everyday! |
#3 posted 10-04-2015 06:06 PM |
Wouldnt use fillers. I’d cut the mess out and glue in a new piece of wood and shape it. On a lathe preferably. -- Shooting down the walls of heartache. Bang bang. I am. The warrior. |
#4 posted 10-04-2015 06:55 PM |
thought about that but way too many peaks n valleys am afraid. also the rim is still intact so do not want to disturb that -- Learn something new everyday! |
#5 posted 10-04-2015 11:04 PM |
I would say if it has no personal value (like something passed down), I would junk it and find a replacement. Replacements are plentiful enough. -- Mike |
#6 posted 10-04-2015 11:43 PM |
What Mike said is probably true, but I like to try to save things too. Fridge’s way is probably the easiest and would work, you just need to turn away enough to make a round tenon to glue into the extra piece. That’s a way better option than fillers that won’t match grain etc. The only real other option is to cut the waste off and make a perfect flat then glue on an extra piece and shape that. You’ll see the repair almost no matter what you do, so you’ll have to decide if all the effort is worth it to you. If you just want a learning experience, have at it. |
#7 posted 10-05-2015 01:36 AM |
this plane came with a severed tote which i was able to glue back nice n solid…n since i was in the mood to take on the challenge but i might have to replace it. ....so where can i go get a stanley no.4 knob replacement? i’m new to all this…thanks! -- Learn something new everyday! |
#8 posted 10-05-2015 01:40 AM |
nhplaneparts.com on ebay….. -- A Planer? I'M the planer, this is what I use |
#9 posted 10-05-2015 04:04 AM |
nhplaneparts.com on ebay….. will chk it out…thanks btw, are there various size knobs…if that’s the case it means that i have to get a replacement threaded rod -- Learn something new everyday! |
#10 posted 10-05-2015 04:33 AM |
He has them as well….just about any stanley plane part is in his store… -- A Planer? I'M the planer, this is what I use |
#11 posted 10-05-2015 10:47 AM |
http://www.timetestedtools.com/knob-base-repair.html -- http://timetestedtools.net - Collecting is an investment in the past, and the future. |
#12 posted 10-05-2015 02:21 PM |
i knew i needed a lathe.. shhh, don’t tell the wife…going to use “honey, look what showed up at the door” routine. -- Learn something new everyday! |
#13 posted 10-05-2015 05:12 PM |
It really doesn’t matter. With every tool obtained, there is another that is needed. -- http://timetestedtools.net - Collecting is an investment in the past, and the future. |
#14 posted 10-05-2015 05:40 PM |
#15 posted 10-05-2015 05:58 PM |
I have made repair similar to the one pictured. Think in terms of carving instead of turning. Here’s my attempt to describe what I did: 1. Find an area on the knob where you can sand the surface flat (you are doing a small area at a time).
Repeat steps 1-4 all the way around the knob. You can also do a wedge shape piece as well. A chisel/carving knife will help you clean the corners. It may take 3-4 iterations to complete the repair. -- I'll be a woodworker when I grow up. HHHOPKS |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6695 |
28064 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4758 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8846 |
