acrylic pen blank
« back to Woodturning forum
Forum topic by 3285jeff posted 10-02-2015 02:07 PM 766 views 0 times favorited 5 replies Add to Favorites Watch
View 3285jeff's profile
3285jeff
159 posts in 1887 days
10-02-2015 02:07 PM
I drilled out a pen blank and needless to say the drill bit wobbled a little and the 3/8 hole turned out 27/64th,,,,I was actually thinking of pouring the hole with something and drilling it back out,,but I’m sure the resin and what it takes to mix it is very expensive,,,lol,,,anyone got any answers to this question,,,,thank you
5 replies so far
View JADobson's profile
JADobson
1235 posts in 2280 days
#1 posted 10-02-2015 02:23 PM
Epoxy might work.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View jeff's profile
jeff
1111 posts in 3634 days
#2 posted 10-05-2015 08:12 AM
How did you go about drilling the blank?.Was the blank square?.Did you use a brad point drill bit?Maybe glue in a wooden dowl and then re-drill.
-- Jeff,Tucson,Az.
View Wildwood's profile
Wildwood
2447 posts in 2304 days
#3 posted 10-05-2015 12:33 PM
Only 0.046875 off; would plug one end of pen tube use liberal coating of epoxy on tube. Insert in the blank and wait 24 hours to fully cure before trying to turn. If glue joint fails using your pen mill or initial turning, just use more epoxy and wait another day.
I use a drill press and machinist vice for drilling my blanks because allows me to clear chips easier & often and do not get out of round hole, or bits running off center. Takes me less than 30 seconds to set up blanks and see if bits running true. I never drill deeper than ¼” before clearing chips.
My drilling procedure might be slower than others using a drill press, but much faster than drilling on a lathe.
Good luck with it!
-- Bill
View TheDane's profile
TheDane
5534 posts in 3832 days
#4 posted 10-05-2015 01:39 PM
Clearing waste(chips) and keeping the rpm’s down is really critical, especially in acrylic. The epoxy fix Bill detailed above should take care of the problem for you.
View moke's profile
moke
1253 posts in 2946 days
#5 posted 10-06-2015 06:34 PM
I usually drill my acrylic out that much over on purpose. With Acrylic blanks it is often is transparent enough to see the tube. ( regardles of color…even dark sometimes) I like to paint my tubes with white spray paint, then paint the inside of the blank white…(use a Q-tip)... I then color the epoxy with a drop of testors model paint…..this will accomplish three things…..if it is all white, it will brighten up your blank, you will not see the tube or glue and in your case you will take up that extra room created in drilling.
One final thing…when you slip the tube in, if it is sloppy the epoxy will fix it, but may settle to the bottom and the blank will be some what out of round…..set the blank on end on top of some wax paper….which will get glued to the blank, be is easily removed. If you use too much epoxy you may get some “overage” inside the tube…..carefully file it with a rat tail file after it dries.
Mike
-- Mike
