Cedar from the big box stores
Forum topic by interpim posted 11-30-2009 07:37 AM 1312 views 0 times favorited 5 replies Add to Favorites Watch
View interpim's profile
interpim
1170 posts in 3458 days
11-30-2009 07:37 AM
I have a question about the cedar fence posts you can buy at your borg’s…
Can those be used for turning? I was thinking of grabbing a cheap 4×4 or 6×6 and cutting it down to create my own blanks for small bowls or vases.
Has anyone done this? and if you recommend not doing it why?
-- San Diego, CA
5 replies so far
View gbvinc's profile
gbvinc
628 posts in 3946 days
#1 posted 11-30-2009 04:12 PM
Sure! As long as it isn’t treated wood, and it has the look you want, go for it.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3286 days
#2 posted 11-30-2009 11:03 PM
I’m sure they could be used. They typically are not dried well, so take that into account. Even so, it should still work. People turn wet wood all the time.
-- http://shepherdtoolandsupply.com/
View Llarian's profile
Llarian
128 posts in 3607 days
#3 posted 11-30-2009 11:10 PM
I’ve resawed them for planters the such. You really have to dig to find ones that’re decent quality, but I don’t see why they couldn’t be turned. I have some 4×4 leftover that I’ll have to try that on this weekend maybe.
They’re very green (made wet mush instead of sawdust), but if you like turning green that’s no big deal.
-- Dylan Vanderhoof - General hobbiest and reluctant penmaker. http://llarian.etsy.com
View bruc101's profile
bruc101
1200 posts in 3541 days
#4 posted 12-01-2009 01:24 AM
I’ve turned many a table leg out of cedar post from the big boxes…about to get out of my price range now though.
-- Bruce Free Plans http://plans.sawmillvalley.org
View LesB's profile
LesB
1728 posts in 3443 days
#5 posted 12-02-2009 09:03 AM
Cedar fence posts is a bit soft for good turning and as already mentioned usually not dry. Fence post grade cedar could be from either Western Red Cedar or Incense Cedar. The latter is particularly soft and often referred to as “pencil wood” because it is literally used to make pencils. They are often sold just as “red cedar” with out distinction.
You will need sharp tools and good technique to get a smooth finish and the softness may make it difficult to mount securly. If you try to sand it to a good finish you will end up with a wavy surface because the soft growth rings will sand out faster than the hard ones.
Check local tree service business in your area for suitable hard wood from trees they remove or trim. You can get some great “free” or inexpensive chunks from them.
Regarding “wet” wood. Look up microwave drying techniques to speed things up.
-- Les B, Oregon
