Home made disc sander project
Forum topic by Shane posted 10-01-2015 10:08 PM 15447 views 0 times favorited 3 replies Add to Favorites Watch
View Shane's profile
Shane
294 posts in 1773 days
10-01-2015 10:08 PM
Well I took the first major step towards getting this done. I bought a Dayton motor off of CL today for $25. 3/4hp 1725 rpm. That should be plenty of power without going over. The guy said he got it at a parts auction and it may not have ever been used. It sure looks pristine. Now to rig up some sort of sanding wheel attachment once my foot heals and I can get back in the shop.
3 replies so far
View distrbd's profile
distrbd
2252 posts in 2408 days
#1 posted 10-01-2015 10:23 PM
What are you going to use for the disc? I have seen them made out of MDF, particle boards, lathe aluminum sanding disc, and old turntable plate.
-- Ken from Ontario, Canada
Shane
#2 posted 10-01-2015 10:26 PM
My plan was to use 3/4 inch plywood. I’m going to take it to TSC and find a pulley/shaft key that will fit it and then drill through the pulley so I can bolt it to a round cut of plywood. I’m hoping to make it a 12 inch disc
View Woodknack's profile
Woodknack
11469 posts in 2342 days
#3 posted 07-17-2016 05:21 PM
I’m probably saying what you already know but there are ways to make the pulley and disc concentric and I would recommend flattening the disc after you have it mounted on the motor. You could even make the pulley from wood.
