Walnut Side Table Quandry
Forum topic by docspencer posted 10-01-2015 08:07 PM 15182 views 0 times favorited 10 replies Add to Favorites Watch
View docspencer's profile
docspencer
378 posts in 2182 days
10-01-2015 08:07 PM
Topic tags/keywords: question walnut side table
I have two nice pieces of walnut that I plan to use to make a side table. Both pieces are variegated in color – mostly dark in the middle and lighter on the outsides. Neither piece is wide enough to use alone for the table top. In fact, I don’t like using single wide boards for table tops for fear of warping. In any event, given the differences in color deciding how to cut and put them together seems tricky. Also, until I actually start cutting I can’t visualize how different combinations of cuts and joining together would look. I hope this makes sense. I would imagine some of you folks have faced this before – any ideas about how to proceed? I can post a picture or two of the two boards if it would help.
10 replies so far
docspencer
#1 posted 10-01-2015 08:34 PM
These aren’t my boards, but mine look like this.
View jdmaher's profile
jdmaher
440 posts in 2816 days
#2 posted 10-01-2015 10:08 PM
Cut off the sapwood (the lighter color on the outsides of the boards), then make a panel out the boards of remaining heartwood (the darker color on the inside).
You could just throw away the offcuts, but I save the sapwood as scraps for making components that will not be seen (interior components).
-- Jim Maher, Illinois
View Roger's profile
Roger
20965 posts in 3041 days
#3 posted 10-27-2015 11:48 PM
I like a little sapwood showing in some Walnut projects. That’s just me tho. Good luck with what you decide and how
View Aj2's profile
Aj2
1950 posts in 2035 days
#4 posted 10-28-2015 02:23 AM
I don’t see a good set of boards for a top.I would look for better set.
-- Aj
View Daruc's profile
Daruc
460 posts in 1370 days
#5 posted 10-28-2015 02:31 AM
I take a picture of the boards,
import them into a sketchup drawing,
then trim or flip as needed until you get what you want.
View MNgary's profile
MNgary
303 posts in 2654 days
#6 posted 10-28-2015 04:06 AM
Please don’t confuse us with a pic of 4 pieces that ain’t what you are talking about—okay? With 2 pieces, I would just slide, flip, and look until I saw what I liked. If I didn’t see something beautiful, I’d put them on the shelf for another project.
-- I dream of a world where a duck can cross the road and no one asks why.
View rwe2156's profile
rwe2156
3230 posts in 1718 days
#7 posted 10-28-2015 11:56 AM
For a tabletop especially, in the ideal situation, you want boards cut consecutively from a log because you get the best grain match that way.
If that isn’t possible, then you at least want boards of similar grain pattern/color density.
Sounds to me like you need a diff set of boards.
View BuzzCut's profile
BuzzCut
17 posts in 1180 days
#8 posted 11-01-2015 04:21 PM
I’s be tempted to laminate it with 1/4” maple strips between the boards.
-- www.telenator.com
View BurlyBob's profile
BurlyBob
6031 posts in 2502 days
#9 posted 11-01-2015 04:24 PM
Doc if you got pieces with wild grain and want to make a conversation piece, mix the up. I like the idea of using that sap wood like Roger. It would keep it from getting boring.
docspencer
#10 posted 11-01-2015 07:05 PM
Wow. Thanks for all the input. This is one top I made – sapwood included. I think I like the way the different colors show with the elliptical.
