Small bevel gauge
« back to Hand Tools forum
Forum topic by bdresch posted 10-01-2015 03:24 PM 8639 views 0 times favorited 5 replies Add to Favorites Watch
View bdresch's profile
bdresch
143 posts in 1607 days
10-01-2015 03:24 PM
I am making a stool that includes several angled thru tennons. I started by hand cutting the mortises. Now I want to transfer the angle of those mortises to cut the tenon shoulders. Does anyone know of a small bevel gauge with a blade less than 3/4”? Otherwise I’m not totally sure how I am going to transfer those angles. The mortises are 3/4” square.
5 replies so far
View Kazooman's profile
Kazooman
1006 posts in 1951 days
#1 posted 10-01-2015 03:45 PM
Stick a piece of 3/4” square stock in the mortise and use that as the reference for adjusting your bevel gauge or scribe along the leg onto the stock to determine the proper angle.
View jdh122's profile
jdh122
1012 posts in 2817 days
#2 posted 10-01-2015 03:48 PM
What he said.
But how did you cut the mortises without knowing the angle?
-- Jeremy, in the Acadian forests
bdresch
#3 posted 10-01-2015 04:11 PM
This was my first time doing angled M & T, so bear with me. I used my drill press with the table tilted to bore out most of the waste. I had to cut 3 in a row, but my drill press didnt have enough throat depth to get them all in 1 setup, so the holes werent perfectly in line (screwed up a bit on my second setup). Because the holes werent in line, I had to open them up a bit to correct that when i finished them by hand. Now they are in line, but the angle is slightly different from where I started.
I’ll try mill up a piece of stock to measure. If I ever do this again, I’ll cut a piece of stock at my angle to support the workpiece instead of tilting the table. Lesson learned.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1574 days
#4 posted 10-01-2015 05:14 PM
If your drill press is still set up with the drill angle,take a piece of scrap drill a hole,stick a dowel in it and you have a fixed bevel gauge,with the exact angle.
bdresch
#5 posted 10-01-2015 06:04 PM
Drill press has long been changed. This is one of those projects that has lingered on for months.
