Craftsman Miter Gauge Help
Forum topic by Chris posted 09-30-2015 07:14 PM 791 views 0 times favorited 6 replies Add to Favorites Watch
View Chris 's profile
Chris
177 posts in 1549 days
09-30-2015 07:14 PM
I use an old craftsman 113 series I inherited from my father in law who has passed away. The saw came with this miter gauge. I am having trouble figuring out how to loosen the gauge to be able to cut at an angle. Initially, I thought I would just spin the knob on the back end and adjust and re-tighten. However, I can’t loosen that knob for the life of me. I tried to use plyers and started to dent the metal that on the knob … I am not experienced or proud so please feel free to ask the most basic questions or provide basic advice I am just overlooking.
Thanks in advance.
View sawdust703's profile
sawdust703
270 posts in 1385 days
#1 posted 10-01-2015 02:41 AM
By the looks of if it, it shouldn’t need to be loosened. Just pull out the adjustment pin under it, adjust to your desired angle, or until the pin catches a stop hole, & you’re ready to go. The handle is to hold onto while you’re using the miter gauge.
-- Sawdust703
View vanillaman's profile
vanillaman
5 posts in 1063 days
#2 posted 10-01-2015 05:53 PM
Chris…......I have that same table saw w/ miter guage. I also inherited mine from the FIL. That knob must be loosened by turning CCW, and then pull back on the pin to allow it to turn. I would try penetrating oil and allow it set a while, then try it. When I get a chance I will take a look at mine and if I see anything that may I will get back too you with my findings.
Dick
-- Dick,Maine
View SirIrb's profile
SirIrb
1239 posts in 1195 days
#3 posted 10-01-2015 06:31 PM
Those dang pins usually stick like no ones business.
View dhazelton's profile
dhazelton
2755 posts in 2261 days
#4 posted 10-02-2015 12:55 PM
Also, don’t try pulling on the back of the pin – try wedging a small screwdriver (or something that won’t mar the metal) between the front of the pin and gauge itself. Then pry it back.
View johnstoneb's profile
johnstoneb
2867 posts in 2137 days
#5 posted 10-02-2015 12:57 PM
The best thing you can do with those old miter gauges is replace them with an Incra or equivalent. They just aren’t that accurate.
-- Bruce, Boise, ID
Chris
#6 posted 10-02-2015 01:10 PM
You guys are the best! I thought the pin turned and didn’t realize the handle needed to turn and the pin just needed to pull back. I was able to use this towards my shop made bandsaw fence last night and adjust for blade drift by changing the angle a little bit. Thanks again for the help!
