Work Sharp 3000 with 2000 discs
Forum topic by Jason9102983 posted 09-30-2015 05:22 PM 642 views 0 times favorited 0 replies Add to Favorites Watch
View Jason9102983's profile
Jason9102983
4 posts in 1288 days
09-30-2015 05:22 PM
Topic tags/keywords: work sharp 3000 work sharp 2000 work sharp 2000 discs work sharp 2000 discs on 3000 slotted discs slotted wheels slotted abrasive
I hadn’t seen this posted anywhere so I thought I would post it.
The Work Sharp 3000 slotted discs are really absurdly expensive. The slotted abrasive wheels are labeled as for 2000 or 3000 only. The 2000 wheels work fine on the 3000. If you only have 3000 sandpaper on hand like I did you have to spend a little bit getting the two sides of sandpaper aligned and visibility is less than with the 3000 discs, I believe it is due to the extra mass of plastic. Tried to take a picture to compare the two but it was difficult to show the 2000 wheels visibility. The 2000 disc slots are uniform and larger than the 3000’s.
Here is a picture to get an idea of the differences.
Image and video hosting by TinyPic
0 replies so far
