Grinder Speed to Sharpen
Forum topic by davidroberts posted 11-29-2009 05:50 AM 1274 views 0 times favorited 6 replies Add to Favorites Watch
View davidroberts's profile
davidroberts
1027 posts in 3479 days
11-29-2009 05:50 AM
Topic tags/keywords: sharpen grinder
I want to try and grind a bevel in a test chisel. Until now, I’ve used water stone. I have an old Cman 3450rpm grinder and bought a white wheel, but now I’m starting to believe 3450 rpm may be to fast, especially given the popularity of the tormak low speed grinder. So what speed grinder do you use to put a bevel on a chisel. Thanks!
ps, I bought the veritas angle jig for use with a grinder, so I do have a guide.
-- Better woodworking through old hand tools.
View MedicKen's profile
MedicKen
1615 posts in 3456 days
#1 posted 11-29-2009 06:16 AM
I am using a 1/3hp motor that is 1725 rpm. Be careful and use a very light touch when grinding and dont burn the edge. If you get any bluing of the steel it will have to be ground off. Have some water nearby to cool the blade between passes.
View jack1's profile
jack1
2107 posts in 4021 days
#2 posted 11-29-2009 06:25 AM
or oil. that works too. I need a slower grinder too.
View mski's profile
mski
439 posts in 3974 days
#3 posted 11-29-2009 06:41 AM
I have a 20 year old Harbor frt 3250 rpm , I got a white wheel and had a he%# of a time until I bought a diamond cutter to true the wheel, works excellent for my lathe tools but planes and bench chisels takes some practice not to burn and you will never get them to useable sharpness without hand honing anyway even with a 1750 rpm, so if you jump, jump all the way to a slow speed wet wheel.
There are some cheaper versions of the tormak from HF ,Grizz and another german (Starts with S I think) one on Amazon that I would get to save ALOT of $ ,but I do not have the need, past lathe tools.
Me 2c
-- MARK IN BOB, So. CAL
TopamaxSurvivor
18265 posts in 3669 days
#4 posted 11-29-2009 08:12 AM
My grinder is an old Craftsman, 25-30 yrs old. I think hi-speed. I just keep water handy to cool. I sharpen everything from lawn mower blades to chisels, dril bits and and plane irons on it. I do the final touch up by hand on the precision stuff. Most of the time I keep coarse and fine wheels on it. The lawn mower blade never touches the fine wheel :-)) You can use any seed grinder and long as you know what you are doing and don’t burn the edge. Somebody on here said the modern tools steels can be burned without taking the temper out. Just be careful and keep things cool and you won’t have to worry about it.
View Derek Cohen's profile
Derek Cohen
370 posts in 3962 days
#5 posted 11-29-2009 05:19 PM
Do NOT use the grey wheels that comes with most grinders. Get either a white or blue Nortons at either 36 or 46 grit. You want a coarse wheel for cool grinding. The smoother wheels are for HSS lathe chisels (which do not burn). A very light touch is still needed. Keep a finger on the blade near the edge to check for heat.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View bigike's profile
bigike
4052 posts in 3282 days
#6 posted 11-29-2009 05:46 PM
i have a delta and it has a speed knob to slow the wheel down i put it all the way to the slowest speed posible and grind on that speed u can get one for about $60-$100 on ebay the only thing is it comes with a grey wheel an a white one dont know the grits but the white one i want to change to get a better one like from norton but need to know the best grit to get? but for now it works for me.
