Hand plane for table top glue ups
Forum topic by BalsaWood posted 09-30-2015 07:36 AM 687 views 0 times favorited 5 replies Add to Favorites Watch
View BalsaWood's profile
BalsaWood
47 posts in 1127 days
09-30-2015 07:36 AM
I am making an oak table top. I glued up some oak boards and one of the boards ended up slightly higher on one end. I was thinking of some of my options for leveling the board. I don’t have much experience with hand planes so was wondering which hand plane would be good for flattening the table top glue up?
5 replies so far
View bondogaposis's profile
bondogaposis
4688 posts in 2320 days
#1 posted 09-30-2015 12:35 PM
It depends on how much wood you need to hog off. If it is a lot start w/ a jack, then go to a jointer and then final pass w/ a smoother. If it is just a sliver of wood to begin with go straight to the smoother. A table top doesn’t have to be dead flat, it just has to look flat to the naked eye.
-- Bondo Gaposis
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2338 days
#2 posted 09-30-2015 12:49 PM
I just finished a table top that had a board or two like that (need to make some better cauls). I started of going cross-grain with a #4 taking a moderate amount off, to get it level front-to-back. Then I switched to a jack and did front-to-back, at a 45, down the length, then down the length with a jointer. Skipped the smoothing plane in favor of the ROS, because the surface was pretty good after the jointer.
View JayT's profile
JayT
5589 posts in 2180 days
#3 posted 09-30-2015 01:29 PM
I like a #5-1/2 or #6 for flattening panels. Others prefer something slightly larger or smaller—anything from a #5 on up in size should work fine.
BalsaWood
#4 posted 09-30-2015 04:05 PM
Right now, all I have is a low quality smoother plane. If I purchased a jack plane, could I do all the above with it?
BinghamtonEd
#5 posted 09-30-2015 04:12 PM
- BalsaWood
Yes, you could. I’d cross-grain, followed by 45 degrees to that in one direction, then 45 in the other direction, then along the length, all taking thin shavings. I did my benchtop with a #5 before I got the #7, it’ll work. Scribbling across the top with a pencil will also help you see where the high/low spots are. Winding sticks, if needed.
If you have any antique stores near you, they’re a good place to look. Also Craigslist. Or, if you can afford to go new, I hear the WoodRiver and Veritas are nice, but I wouldn’t know. I picked up a #5 and 2 #4s (only enough salvageable to make 1 #4 from them) off Craigslist for $15.
Whatever route you go, make sure the sole is flat, and the blade is sharp.
