cutting board
« back to Joinery forum
Forum topic by wiser1934 posted 09-30-2015 03:10 AM 640 views 0 times favorited 1 reply Add to Favorites Watch
View wiser1934's profile
524 posts in 3082 days
09-30-2015 03:10 AM
Topic tags/keywords: question
what i want to do is put an end piece on the board fastened to end grain. i know that end grain does not glue well, so i figured that i could use dowel pins to fasten the two together. just use glue on the center pin to allow for expansion, etc. will this work??
-- wiser1934, new york
1 reply so far
View Mr M's Woodshop's profile
Mr M's Woodshop
420 posts in 3002 days
#1 posted 09-30-2015 03:35 AM
So you’re doing a bread board end? That’s a stiffener that runs across the grain of an edge grain board. Those are often used as in-counter boards, and generically as thinner boards used for rolling out bread dough. Since the board is thinner, the end piece is added to stiffen the board and prevent warping. Typical joinery is tongue & groove, but that can definitely be supplemented with dowels to pin the long tongue into place.
Here’s one I recently made, just to make sure we’re talking about the same thing!!!
-- Henry Mowry, Santa Clarita, CA,
