HELP !!
Forum topic by Dusty56 posted 11-28-2009 09:48 PM 993 views 0 times favorited 4 replies Add to Favorites Watch
View Dusty56's profile
Dusty56
11819 posts in 3597 days
11-28-2009 09:48 PM
Topic tags/keywords: question trick tip oak finishing
Hello everyone,
I picked up some Curly Red Oak the other day and I need some help as far as what to use to make this curl POP for me . The other issue is that the boards are not from the same tree nor are they the same color : (
As much as I hate to stain or dye my projects , I’m afraid that it will be necessary to do that to achieve a uniform color this time.
A friend recommended TransTint dye mixed with BLO to POP the grain and perhaps a Shellac on top of that . What are your thoughts on these matters ?
Thank you
Len
View Andrew's profile
Andrew
709 posts in 3108 days
#1 posted 11-29-2009 12:36 AM
As far as the grain pop goes, I like to rub with mineral oil first .Seal with a wash coat of shellac, then fill the pores, oak has large and open pores. Then another layer of shellac, and then use a gel stain to blend the color differences. After that you can put what ever you like over it to protect it.
Cant wait to see it.
-- Even a broken clock is right twice a day, unless, it moves at half speed like ....-As the Saw Turns
116913 posts in 3486 days
#2 posted 11-29-2009 01:31 AM
Charles Neil has a video on you tube on how to make grain pop.
View matt garcia's profile
matt garcia
1884 posts in 3581 days
#3 posted 11-29-2009 05:14 AM
Let’s see it!!!!
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
View jack1's profile
jack1
2099 posts in 3936 days
#4 posted 11-29-2009 06:24 AM
I’ve just sanded until I didn’t want to anymore (400, 600) then seal, then light wax or satin poly. I guess it depends on the board and your taste too though…
