Electrical question
Forum topic by Rxmpo posted 09-29-2015 01:57 AM 952 views 0 times favorited 9 replies Add to Favorites Watch
View Rxmpo's profile
268 posts in 3680 days
09-29-2015 01:57 AM
I have been updating my shop and moving my tablesaw to the other side of my basement shop. I have a 50amp subpannel in the basement and had a 220 outlet installed just a foot from the panel for my SawStop. Now the outlet is being moved to about 50 ft from the panel. I had originally had 12 gauge wire for the short run, but I want to know if I should be using 10 gauge wire for the longer run or if 12 gauge is fine. Any help would be appreciated…
9 replies so far
View bigblockyeti's profile
5057 posts in 1655 days
#1 posted 09-29-2015 01:58 AM
How many amps is the receptacle?
#2 posted 09-29-2015 02:12 AM
20 amp
View David Taylor's profile
David Taylor
326 posts in 1021 days
#3 posted 09-29-2015 02:31 AM
According to this site, Voltage Drop Calculator, the voltage will drop by 1.33% to 236.82V over 50 feet with 12 AWG. With 10 it will drop 0.83% to 238. Your call, seems to me.
-- Learn Relentlessly
#4 posted 09-29-2015 02:36 AM
Thank you DYFHID!
View TheFridge's profile
9095 posts in 1420 days
#5 posted 09-29-2015 02:37 AM
#12 is plenty.
5% is the max including to the sub panel.
I don’t do calculations for anything less than 100-150 ’ depending on load.
#6 posted 09-29-2015 03:01 AM
You guys rock…
18227 posts in 3610 days
#7 posted 09-29-2015 08:00 AM
The acid test is there any noticeable hesitation on start up?
View Lenny's profile
1593 posts in 3461 days
#8 posted 09-29-2015 11:28 AM
I was going to refer your question to Bob (TopamaxSurvivor) but he already chimed in. Good luck on the shop rehab Mike. Have fun doing it!
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
#9 posted 10-01-2015 05:10 AM
Thanks all! TS I will be on the lookout once everything is completed.
Thanks Lenny. This has been a labor of love and just getting everything in its new home has been interesting to say the least!
