Easy finish suggestions for Curly maple and african Mahog chess board
Forum topic by Mcnervy posted 11-28-2009 07:55 AM 7250 views 0 times favorited 13 replies Add to Favorites Watch
View Mcnervy's profile
Mcnervy
108 posts in 3068 days
11-28-2009 07:55 AM
Topic tags/keywords: question finish maple newbie
I am an overtooled newbie (god that word sounds week) and i need some help.
I am building a chess board
I have Curly maple and african mahoghany squares
I plan a bloodwood and zebra wood mitered boarder
I would like sugestions on a good quality finish that is relitivly easy
Current plan
sand up to 220
Apply pure tung oil
wait 20-30 minutes remove
repeate for total of 3 coats
Let dry
Wipe on poly 3 coats
Please Correct my plan or suggest a better one
Thanks
-- Bennett; If it can't be fixed with a hammer its an electical problem
13 replies so far
Rick Dennington
5805 posts in 3159 days
#1 posted 11-28-2009 05:09 PM
Hey Mcnervy: Your solituion sounds fine, and you can do what you want to, but this is my recepie( This is ONLY me). I’d take 1/3 tung oil, 1/3 boiled linseed oil, 1/3 poly, and 1/3 mineral spirits, mix it all together in a mason jar, stir it real good, and put it on the chess board, either with a brush on wipe-on. Let dry good, buff it with 0000 steel wool, put on another coat, repeat the process until you get about 3-4 coats on. Let it dry good, and polish it with a paste wax like Johnsons, or a carnuba wax. That way you can eliminate the 3-4 coats of tung and 3-4 coats of poly. A one-step process with this formula, and your down-time is reduced. hope this helps.
Mcnervy
#2 posted 11-29-2009 02:29 PM
Rick
I think you have 4 thirds you mean 1/4 part each right?
Mcnervy
#3 posted 11-29-2009 03:11 PM
CPB What thinning agent would you recomend
I have some behr wiping poly i could use
View BeeJay's profile
BeeJay
71 posts in 3152 days
#4 posted 11-29-2009 03:19 PM
Mate, that is a really nice mix of wood and grain. For the love of wood, lets forget the shortcuts.
I recommend 3 coats of tung oil, 2 coats of danish and polish off with brown wax.
-- If you try to fail and succeed, what have you done?
Mcnervy
#5 posted 11-29-2009 04:18 PM
BeeJay
I am not familar with danish oil
Does it protect?
What should final sanding grit be? I am thinking 220
Thanks
Bennett
16274 posts in 4183 days
#6 posted 11-29-2009 04:37 PM
Any of the suggestions given above will work fine. But the first thing you have to know is what you want the final result to look like. Then you can decide the best way to get there.
The first and most important questions I ask myself on every project: Glossy or not? Do you want the texture of the wood to remain to the extent that you can feel it with your fingers, or do you want a smooth-as-glass surface?
My suggestion would vary a lot depending on the answers to those questions.
Rick Dennington
#7 posted 11-29-2009 09:48 PM
Hey Mcnewrvy: Sorry about the wrong parts> I WAS thinking 1/4 parts when I was typing, but kept hitting the 3!!! lol lol. I’d had too much grub, I guess, and was ready for a nap—latharligc!!! By the way—really nice chess board you made. But one more thing you could do once it’s made: with your great wood choices, you could just use straight mineral oil, just like on a cutting board. Apply, let soak in, wipe, dry. Repeat a couple of times. Just my nickel!!!!
CPB: You don’t have to use the tung oil if you don’t want to. I just use it as a nother ingredient with the poly and mineral spirits. I use the BLO more as a drying agent, and speeds it along. I’m competely out of Japan dryer, so that’s why I use it. Some do—some don’t. Competely up to you.
Mcnervy
#8 posted 11-30-2009 03:08 AM
i attached the boarder today
I failed with the zebra wood it sprang shut on the blade so hard that the blade stopped and blew the circuit breaker.
I think the blood wood looks sharp though
View Chuck 's profile
Chuck
88 posts in 3164 days
#9 posted 11-30-2009 03:23 AM
I’m also a newbie, so take this with a grain of salt, but I recently discovered Waterlox. The stuff is awsome.
-- Chuck, Washington D.C.
BeeJay
#10 posted 11-30-2009 05:38 AM
Bloodwood looks fine and will come up very nice when finished. Danish (Scandanavian Oil) oil is similar to the mixes some people still make themselves. It contains Tung Oil and several other oils and a small amount of lacquer. It penetrates quite deep and sets hard on the surface.
117062 posts in 3541 days
#11 posted 11-30-2009 05:49 AM
One coat Seal Coat and two of waterlox.
Mcnervy
#12 posted 12-01-2009 06:54 AM
!http://i1014.photobucket.com/albums/af269/mcnervy/miter.jpg1
AND
now i really dont want to ruin it
BeeJay
#13 posted 12-02-2009 12:58 AM
Nice
I like lots.
Nice cutting too.
