Iturra Replacement BS Spring
Forum topic by Cortland posted 11-28-2009 06:13 AM 1682 views 0 times favorited 3 replies Add to Favorites Watch
View Cortland's profile
Cortland
21 posts in 3106 days
11-28-2009 06:13 AM
I am restoring a vintage Delta 890 band saw and planned to replace the spring with an Iturra. I just noticed that the “Delta style” spring is listed as 2-1/2” while the “Jet style” is 3”. My old spring may or may not be the original, but it measures about 2-3/4”. Should I order the Delta and shim it out? Or order the Jet and crank it a little tighter? Would a quarter inch make any real difference?
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3621 days
#1 posted 08-03-2010 11:30 PM
Ouch your avatar looks like that really hurt!
What spring did you eventually go with?
Cortland
#2 posted 08-03-2010 11:51 PM
I didn’t want to take a chance, so I ordered the Delta spring from Iturra. I did not shim it, and I can’t tell any difference, so the spring I replaced may not have been an original Delta part in the first place. A few photos of my fully restored 1934 Delta model 890 appeared in the Winter 2010 Iturra catalog.
Mark Shymanski
#3 posted 08-04-2010 05:50 AM
A great looking restoration.
