M&T that can be disassembled
« back to Joinery forum
Forum topic by jeff788 posted 09-29-2015 12:26 AM 843 views 0 times favorited 4 replies Add to Favorites Watch
View jeff788's profile
jeff788
1 post in 1211 days
09-29-2015 12:26 AM
Hi Everyone,
I’ve been lurking on here for a while and just joined to ask my first question. I’m new to woodworking and am primarily learning to use hand tools. I’m building a bassinet/co-sleeper as my first real project. It is coming along well but I just had a thought: we are likely to be moving within the next four months and it would be really nice to be able to disassemble the bassinet for transporting and storing in the future. The main joints between the side rails and the posts are going to be through mortise and tenon joints. Is there a good way to do a M&T without glue such that it could be disassembled and reassembled? I’ve searched on here and elsewhere and I’ve read about a draw bored M&T. Many say they are strong enough not to need glue, but I question how well they would disassemble and reassemble. I’m not opposed to using metal fasteners, though I really like learning more traditional (perhaps?) ways of doing things. If I were to use metal fasteners, what would be the best type and design to choose?
Thanks,
Jeff
View lateralus819's profile
lateralus819
2241 posts in 2129 days
#1 posted 09-29-2015 12:28 AM
Since you’re doing through tenons already, just make the tenons longer and use wedges. It looks really cool too.
View theoldfart's profile
theoldfart
10303 posts in 2691 days
#2 posted 09-29-2015 01:35 AM
+1 to Lats idea. You won’t be able to disassemble draw bored M&T readily without doing considerable damage.
If hardware is your preferred route try barrel bolts.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View ElChe's profile
ElChe
630 posts in 1576 days
#3 posted 09-29-2015 02:13 AM
+2 on wedged tenons. Various styles including vertical wedge above or horizontal wedge or using two wedges. Nice design touch.
View ChefHDAN's profile
ChefHDAN
1230 posts in 3089 days
#4 posted 09-29-2015 04:20 AM
As A father of more than 1 I agree with the above that a wedge tenon would enable you to disassemble the bassinet for future use
