Stain still tacky one week later
Forum topic by Northuplander posted 09-28-2015 07:27 PM 1684 views 0 times favorited 16 replies Add to Favorites Watch
View Northuplander's profile
Northuplander
3 posts in 934 days
09-28-2015 07:27 PM
OK, I confess, I likely didn’t sand down my cabinets as well as I should have before staining. So now I have a full set of kitchen cabinets and two sets of bathroom cabinets all oak and all still tacky one week later. I have large areas of the cabinets that are dry, and have been using fans to circulate air. Is there anything else I can do to speed things up? I have my A/C on as well, but since temps are in the low 70’s it is not always running I think the fans are helping but it will take another week at least, maybe much longer, to get all the spots based on my experience last few days. Is there anything else that would help. I am worried that if I try to wipe it down that it will smudge pretty bad and make it look worse since it is not wet to the touch, just tacky and very tacky. Hoping to get my poly on before Christmas. Thanks!
16 replies so far
View Tennessee's profile
Tennessee
2860 posts in 2477 days
#1 posted 09-28-2015 07:46 PM
The ONLY thing I can think of is to thin your finish coat, adding a drying agent/solvent, and when you put it on, hope it carries the weight of finishing the drying of the stain. I’ve gotten away with it once or twice, but more often than not, I had to take off the stain and finish sanding the wood.
Good luck…
View Dallas's profile
Dallas
3599 posts in 2449 days
#2 posted 09-28-2015 07:48 PM
Stain tacky? Just how much did you put on?
It should have soaked in in about 15 minutes and been wiped in an hour or so.
Stain is not a finish, it is a colorant for the wood. At this point I don’t really know what to tell you, and believe me,I am not yelling at you for doing it…. I had it happen to me many years ago.
Is this oil base or water base stain? Maybe someone will chime in with a bunch more experience than I have.
I am but a grasshopper.
4944 posts in 2455 days
#3 posted 09-28-2015 08:06 PM
I’m puzzled why you mentioned you didn’t sand them down enough. Whether you did or not is unrelated to your problem. Knowing a little more about what stain it is that’s giving you problems would help. Also, is this a fresh can? How did you apply, did you do as Dallas described?
View TheFridge's profile
TheFridge
9249 posts in 1448 days
#4 posted 09-28-2015 08:22 PM
I give it a wipe with mineral spirits whenever I have drying issues. Just me.
Northuplander
3 posts in 934 days
#5 posted 09-28-2015 08:24 PM
I wasn’t clear at first. I stained cabinets that were previously stained and thin poly coated. I think I may not have removed all the poly when sanding, hence the stain not sinking in completely and instead just getting tacky on the surface. Stain is a brand new oil-based Minwax stain.
View johnstoneb's profile
johnstoneb
2858 posts in 2135 days
#6 posted 09-28-2015 09:20 PM
Minwax is your problem. It won’t dry you will have to do as Tennessee suggested and put another coat of finish over it. I had the same problem with Minwax and don’t use it anymore.
-- Bruce, Boise, ID
View ChefHDAN's profile
ChefHDAN
1047 posts in 2812 days
#7 posted 09-28-2015 09:27 PM
Still tacky sounds like too much stain left on surface or has been said the prior poly kept it from absorbing the stain to begin with. You can rub down with MS to see if the excess will remove and if it takes it all of then you know the prior poly is the culprit. Did you do the prior finish, do you know that it’s a poly finish?
FWIW, there is a product called KrudKutter stripper that I have used to refinish some garage sale finds that works fairly well with removing old finishes, a bit faster than sanding, and pretty easy to work with, it’s not a gnarly burn your skin off product.
Northuplander
3 posts in 934 days
#8 posted 09-29-2015 12:17 AM
Hi, TheFridge, that suggestion is of interest to me. What I wanted to get a better handle on is how saturated is the cloth you use to swipe and how much pressure would you apply? I know there can’t be a definitive formula as it depends on each situation, but what is your gut on this?
Thanks to all you guys for your input.
View gfadvm's profile
gfadvm
14940 posts in 2652 days
#9 posted 09-29-2015 12:19 AM
I think a coat of shellac will cover that stickiness and allow you to move forward with your final finish. I am amazed at what shellac will seal over!
View jumbojack's profile
jumbojack
1674 posts in 2586 days
#10 posted 10-01-2015 04:22 AM
Wipe it with mineral spirits. Give it a day presto.
View RogerM's profile
RogerM
792 posts in 2361 days
#11 posted 10-01-2015 11:50 PM
A coat of Seal Coat followed by some polyurethane should solve your problem.
-- Roger M, Aiken, SC
TheFridge
#12 posted 10-02-2015 12:06 AM
I use just a splash on a rag and wipe it. Not much too it really.
View Daruc's profile
Daruc
460 posts in 1095 days
#13 posted 10-02-2015 12:17 AM
I would wipe it all down with lacquer thinner and finish sanding off all the old poly. Basically start over.
These are kitchen cabinets, you want a solid product. That’s what I would do if they were mine.
In my opinion the mineral spirits is just going to make a mess, but if your going with the thought of wiping it all down and starting over, then you have nothing to lose. Just try to keep the color even as your wiping.
View Arlin Eastman's profile
Arlin Eastman
4175 posts in 2523 days
#14 posted 10-02-2015 12:34 AM
Most of the time when stain is still tacky it is because it was put on to thick. Did you wipe it down after you put it on? Wipe it with mineral spirits and re-due what needs done again.
I hope it gets better soon
-- Please help me help other Vets click..> http://www.gofundme.com/m1abko.....It is always the right time, to do the right thing.
View TTF's profile
TTF
154 posts in 3140 days
#15 posted 10-02-2015 12:46 AM
Since it’s sitting on a coat of poly, its just going to sit there and eventually harden up. If it’s still not dry after week, I think your not going to have a finish that will last.
If you want them to dry, get a dehumidifier and run it 24×7.
If it were me, I’d get mineral spirits, wipe them clean, sand everything correctly and re-stain them.
I have done a lot of things like this in the past – so no judgement here – but it’s better just to do it right in the end. Less stress, more predictable. I bet you spent way more calories worrying about the stain drying that you would have doing the sanding up front. Again, I’ve done the exact same thing. I think we get to learn the “fun” way…
Anyway, best of luck with it. I hope it looks great in the end.
-- Troy | http://tf-workshop.com | The more I see nature, the more I am amazed at the Creator. - Louis Pasteur
