Grizzly G0654 6" x 46" Jointer sound
Forum topic by david51st posted 11-28-2009 01:53 AM 4310 views 0 times favorited 2 replies Add to Favorites Watch
View david51st's profile
david51st
14 posts in 3490 days
11-28-2009 01:53 AM
Hello All,
I ran my new G0654 6” x 46” Jointer for the first time today. It is the first Jointer I have ever owned. I was wondering what it should sound like? Mine does not “hum” it sounds “rough” nothing is hitting. The blades turn. The rear guard rattles. I took it off and ran again, still just a bit “raw” sounding. Has anyone seen or can some one post a start up test for this unit? Hope that is not too much to ask. The directions keep saying “if strange sound STOP.” I just do not know what qualifies as strange?
Thanks
2 replies so far
View lwllms's profile
lwllms
555 posts in 3276 days
#1 posted 11-28-2009 03:06 AM
Trust your instincts. Try running just the motor with the belt off then try just spinning the cutter head by the pulley with the belt off. Check the motor mount and the cutter head bearing housings. I’m betting there’s a problem you can isolate.
View JJohnston's profile
JJohnston
1622 posts in 3286 days
#2 posted 11-29-2009 03:15 AM
I’m in the process right now of setting up a new G0490 jointer, and I’ve had to track down some noises myself.
1. The belt needs to be really tight. The weight of the motor alone isn’t nearly enough to get proper tension. I had to use a 2×4 as a lever to get it tight (and by “tight” I mean to the spec indicated in the manual). I found that if it isn’t tight enough, it flutters and slaps the motor mount.
2. Make doubly sure your pulleys are aligned, after tightening the belt. Use a straightedge as much as practical.
3. On mine, there are 2 setscrews on the motor pulley, one that bears on the shaft, and one on the key. Both were loose, and both needed some Loctite to keep them from backing out.
4. Make sure the machine is set so the belt is centered in the opening where it comes through the top of the stand.
Even after all that, mine still isn’t super quiet, and I think maybe it’s just the sheet metal of the stand vibrating, and there’s nothing I can do about that.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
