Large frame glue up question
Forum topic by Hutch posted 10-17-2007 11:55 PM 3139 views 0 times favorited 7 replies Add to Favorites Watch
View Hutch's profile
Hutch
106 posts in 3893 days
10-17-2007 11:55 PM
I am making an oak frame for a 4’ H X 7 1/2’ W cork board. I have cut mortises into the vertical pieces and finally trimmed the tenons on the ends of the 7’ pieces to fit. Cut the rabbets into the back and now ready to glue the frame up. Other than using tie-downs and ratchet them tight, how do I glue these up?
Thanks for reading.
7 replies so far
View Thos. Angle's profile
Thos. Angle
4444 posts in 3958 days
#1 posted 10-18-2007 01:30 AM
Hi, Hutch,
I’ve done large frames like this, big door frames for cabinets. I used wedges and a three sided frame screwed to the top of my lay out table. Square up the stationary frame and then glue your large frame and clamp it by driving wooden wedges between the frame and your glue up. Is that clear as mud?
View Matt's profile
Matt
119 posts in 4412 days
#2 posted 10-18-2007 02:00 AM
A couple of ideas that come to mind include taking a piece of square stock, fitting into the inside of each corner and then clamping one clamp to the longer piece and a second clamp to the shorter piece.
The other idea is to create some clamping jigs that have 45 degree notches at one end and flat at the other. Clamp the jigs, one on each piece and one on each end. So a total of 8 for a square frame. Once the jigs are in place you can then apply a third clamp that fits on the 45 degree notches. These third clamps pull the corners tight.
-- Straight grains & sharp blades
Hutch
#3 posted 10-18-2007 03:25 PM
Thanks for the ideas. Tom, I don’t exactly have a picture of the three sided frame and wedge plan. I think I’ll have to do one corner at a time because the frame overlaps my layout table. Thanks Matt, does the 45 degree notch idea work only for mitered corners or also the mortise and tenon joint?
I had to laugh after concentrating on the mortise and tenon joints and starting the dry fit, I just looked at it and said “now what?”
View Betsy's profile
Betsy
3391 posts in 3891 days
#4 posted 10-18-2007 03:31 PM
Hutch – if you google “Bob the Wood Guy” he’s got a quick video on how to glue up picture frames with wedge clamps that I’m sure you can use for this job. I don’t have the link handy and as 8:30 a.m. is quickly approaching – my boss probably wants me to get to work. I’ll try to find it for you at lunch time. It’s a pretty good video.
Betsy
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
View Mark Mazzo's profile
Mark Mazzo
352 posts in 3908 days
#5 posted 10-18-2007 04:10 PM
Hutch,
Since you are not doing mitered corners, you don’t need a band clamp kind of approach to clamping to close and align the miters- so, it gets easier.
If you have some pipe clamps, one way would be to double up 4 foot pipe clamps for each set of M&T joints along the 7 foot length. When I say “double up” I mean that one 4 foot clamp clamps against the tail of the other 4 foot clamp to effective give you almost 8 feet of clamping capacity.
Hutch
#6 posted 10-18-2007 05:45 PM
Thanks Mark.
Betsy
#7 posted 10-19-2007 04:15 AM
Here’s the link I told you about. Hope it helps. http://youtube.com/watch?v=C2trWWHH9dg
I’m not sure I’ve got the link pasted right. But if you go to youtube and search “woodworking + clamping” it will come up. It’s a pretty slick system.
Betsy
