How much can I thin a water based poly?
Forum topic by ric53 posted 09-28-2015 02:51 PM 1179 views 0 times favorited 21 replies Add to Favorites Watch
View ric53's profile
ric53
192 posts in 1423 days
09-28-2015 02:51 PM
Can anybody tell me how much to thin a water based poly to make it a wiping poly?
-- Ric, Mazomanie
21 replies so far
View CharlesA's profile
CharlesA
3305 posts in 1701 days
#1 posted 09-28-2015 02:54 PM
Ric,
My experience is limited to General Finishes High Performance. They say you can thin with 10-20% with water or their extender. I don’t think they recommend more than that. I do wiping varnish a lot, but I’ve found that spraying gives superior results with water-based. Just my two cents.
4873 posts in 2397 days
#2 posted 09-28-2015 02:59 PM
Of the 2-3 brands I’ve used, it was no more than 20% on any of them. Whatever you’re using should say someone on the label or maybe the manufacturer’s tech data sheet. It’s fairly important to stay to their guidelines (IMHO) sine waterbornes can have their chemistry screwed up with too much water. Even so, it’s probably not going to make a good wiping finish; just doesn’t seem to work too well with the waterborne formulas.
ric53
#3 posted 09-28-2015 03:15 PM
Thanks Charles & Fred. I think I’ll go in a different direction. Probably shellac.
-- Ric, Mazomanie
CharlesA
#4 posted 09-28-2015 03:28 PM
The recommended way to “wipe it on” is to use a paint pad applicator with a footsie (women’s hose) over it.
View bonesbr549's profile
bonesbr549
1492 posts in 2971 days
#5 posted 09-28-2015 04:25 PM
Call your mfg and talk to them. I use general finishes and have called and asked questions and applications on a combination of finishing products and they are good and know what they talk about and will flat out tell you since they know their products.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2213 days
#6 posted 09-28-2015 05:06 PM
The different brands that I have used had that information on the can. Your doesn’t?
Not that I’m a fan of min-wax products but they do sell a waterborne wipe on poly. There are youtube videos showing how to apply it.
bonesbr549
#7 posted 09-28-2015 07:06 PM
The different brands that I have used had that information on the can. Your doesn t?
Not that I m a fan of min-wax products but they do sell a waterborne wipe on poly. There are youtube videos showing how to apply it.
- AlaskaGuy
There’s whats on the can and then there is “this is the equip i’m using and the method of application and the medium to be applied to”
What’s on the can is the lowest common denominator for most cases and as reviewed by lawyers. Kinda like that expiration date on eggs.
AlaskaGuy
#8 posted 09-28-2015 07:22 PM
- AlaskaGuy
There s whats on the can and then there is “this is the equip i m using and the method of application and the medium to be applied to”
What s on the can is the lowest common denominator for most cases and as reviewed by lawyers. Kinda like that expiration date on eggs.
- bonesbr549
Not sure what you’re saying. To me it sounds like “don’t bother to read the instructions on the can, the don’t mean nothing”. Is that right?
ric53
#9 posted 09-29-2015 12:19 AM
Some of you are indicating that I don’t read the directions. They all say not to thin but it has been my experience that you can thin even though it says not to. Of course I know enough to read directions and to call manufactures of the products but I mistakenly thought that there may be someone here with some usable answers. This isn’t my first rodeo, in fact I been WW for approx. 30yr’s, but I haven’t had much experience with water based products so pardon my STUPIDITY. I won’t ask a dumb question like this again.
-- Ric, Mazomanie
View gfadvm's profile
gfadvm
14940 posts in 2594 days
#10 posted 09-29-2015 12:24 AM
ric53, Poly and Spar Urethanes (oil based) also state on the label: “do not thin”. I have thinned both with mineral spirits to make a wiping finish with excellent results. I didn’t think your question was dumb at all and I have often wondered about wiping on water based finishes.
View HerbC's profile
HerbC
1721 posts in 2763 days
#11 posted 09-29-2015 12:30 AM
Ric,
Not sure what set you off like that. I don’t read anyone’s comments as being critical of you. The fact that nobody had a better answer than “read the instructions and call the manufacturers” just means that that is pretty reasonable advice.
I hope you don’t take what’s been said here as criticism.
Good Luck with your project.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
ric53
#12 posted 09-29-2015 01:10 AM
Herb, AlaskaGuy’s comment struck a nerve.
-- Ric, Mazomanie
#13 posted 09-29-2015 11:06 AM
ric53, Poly and Spar Urethanes (oil based) also state on the label: “do not thin”. I have thinned both with mineral spirits to make a wiping finish with excellent results. I didn t think your question was dumb at all and I have often wondered about wiping on water based finishes.
- gfadvm
It’s a little different with oil based finishes. They are labeled “do not thin” due the manufacturer’s trying to cover their ass legally relative to VOC content and environmental laws. With waterborne finishes, it’s more about the way they work.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2014 days
#14 posted 09-29-2015 02:35 PM
Correct about VOC laws and many thinning warnings, but there’s more to it for certain solvent based products. All crosslinking finishes, oil based or waterborne, will suffer from over-thinning at some point. Different finishes have different tolerances, as listed on the label.
When crosslinking finishes cure, a chemical reaction takes place where the molecules literally link together. This is why you can’t rub the appropriate thinner on a dry polyurethane or other crosslinked finish, regardless of formulation, and have it change back to a liquid state. To put it simply, if you add too much thinner to a crosslinking finish, the molecules can’t “reach” each other to properly cure. Oil based products can be more forgiving than waterbourne, but they still have a limit.
Waterbourne products, including paints, aren’t really water “based”, they only include a small percentage of water, and the wet product cleans up with water. The real base is usually glycol, a component of anti-freeze, not water. Adding too much water wrecks the formula, which is how it works as you wash the equipment with water.
Examples of non-crosslinking, evaporative finishes include shellac and nitrocellulose lacquer. These don’t cure, they dry, as the solvent evaporates. Wetting the dry film with more of the proper solvent will reconstitute them back to a liquid. You can thin them to literally nothing, almost all thinner, and not mess with the formulation or final dry film quality, only the final film thickness will change. The property that allows them to melt, allows each new coat to melt or “burn” into the last. Some crosslinking finishes (polys, WB, latex paints) may not burn in, which can create visible “witness lines” when rubbed out or sanded.
View Wildwood's profile
Wildwood
2240 posts in 2038 days
#15 posted 09-29-2015 07:16 PM
Water is a carrier for water based/borne products and not really a thinner. Have seen all kinds of water to poly percentages but guess never want to exceed 5%. Too much water and will have a mess!
A simple trick of warming water based products will thin the product to some degree depending upon where you live. Water base products seem easier to apply in warm weather verus cold! Another trick is run the poly through a paint strainer.
Many manufacturers have additives & retarders for spraying but they might not be compatible with other products. Waster based and waterborne products while similar not exactly the same!
Glycol ether is a solvent for retarding water based products and might work for waterborne products not sure. Ask for instructions on mixing water with glcol ether or may end up with a product that never dries.
Ric53, helpful if be specific and tell people product want to use and method of application.
-- Bill
