upcut or downcut spiral bit for mortises?
Forum topic by UncleBen posted 10-17-2007 10:35 PM 2826 views 0 times favorited 10 replies Add to Favorites Watch
View UncleBen's profile
UncleBen
37 posts in 3920 days
10-17-2007 10:35 PM
The title pretty much asks it all, but let me add that I will be using my new Freud 3 1/4 hp plunge router, at only $120 ($100 off, no edge guide). If interested, see this LINK
Anyway, the post is not about the router, but it’s a good deal that some of you might be interested in.
I have heard that an upcut bit will clear chips better, but will have more tearout, and a downcut bit will not clear chips as well, but will have less tearout. How does one decide?
Thanks for the input.
10 replies so far
View Mark Mazzo's profile
Mark Mazzo
352 posts in 3881 days
#1 posted 10-17-2007 11:01 PM
Ben,
For mortises I use an upcut spiral bit. because the mortise is typically covered by another piece and any damage to the mortise edge is not seen. That said, I can’t say that I have ever experienced any tearout. Downcut sprial bits are more useful for things like inlay or marquetry where you require a pristine edge.
I have a post on my blog that describes a jig that I use for router cut mortises and loose tenon joinery.
3809 posts in 3990 days
#2 posted 10-17-2007 11:03 PM
Mortises are usually covered by the tenon piece of the joint so tear out is not a signifcant factor.
Truthfully, I have not seen much difference vs up and down cut bits in the small sizes we use in woodworking.
i.e. under 3/8” generally.
p.s. I did some butterfliy inlays a while back and did not notice a huge difference between either style at 1/8 and 1/4” bit size.
UncleBen
#3 posted 10-17-2007 11:33 PM
Okay, well I’ll just go with an upcut bit.
Thanks
View niki's profile
niki
426 posts in 4048 days
#4 posted 10-18-2007 12:48 AM
I’m using just a simple straight bit and did not have any problems
You can see the mortise jig here
http://lumberjocks.com/topics/636
The test of the jig, here
http://lumberjocks.com/topics/694
The router lift, here
http://lumberjocks.com/topics/665
And some table construction, here
http://lumberjocks.com/projects/2885
Regards
niki
UncleBen
#5 posted 10-18-2007 04:11 PM
Thanks Niki
View SPalm's profile
SPalm
5317 posts in 3850 days
#6 posted 10-18-2007 04:17 PM
You seem to have already chosen, but I agree that upcut will work best for mortises. Actually all three styles will work, but the upcut will clear chips better, and seems to plunge better. Where I see some difference in tearout is on ply, with that thin top sheet. They are usually solid carbide, so handle them with care. With that size of router, make sure to go with 1/2 inch shanks. The difference in a larger shank is amazing.
Steve
-- -- I'm no rocket surgeon
UncleBen
#7 posted 10-18-2007 04:22 PM
Thank you Steve. I had decided on a downcut bit since I thought that was what was supposed to be used, but then I heard otherwise. I also was going to get a 1/4” shank since the bit size I need is 1/4”, but I guess I’ll have to rethink that too. It is a large router and is around 11 pounds, so I’m a little worried about breaking the bit. How would HSS do in comparison?
#8 posted 10-18-2007 05:31 PM
I wanted to add that my experience suggests that only 1/2” blades come on 1/2’ shanks.
Maybe some one could chime in here and tell me where to get 1/4, 3/8” on 1/2” shafts?
I have not seen them in solid carbide – spirals around here.
For what it’s worth, this where I am getting my carbide spirals currently.
Cheers
Douglas Bordner
4023 posts in 4032 days
#9 posted 10-19-2007 06:19 PM
Whiteside makes good spirals.
View Alin Dobra's profile
Alin Dobra
351 posts in 3856 days
#10 posted 10-20-2007 05:13 AM
Down cut clears better the bottom (important for inlays but irrelevant for mortices) and up cut clears better the shavings (desirable). Thus is clearly an up cut bit. As Niki mentioned though, you can easily cut them with a regular bit (much cheaper since you do not need all that carbide).
Alin
-- -- Alin Dobra, Gainesville, Florida
