strength of 2 x 6 roof
Forum topic by jackmo posted 09-27-2015 08:10 PM 799 views 0 times favorited 7 replies Add to Favorites Watch
View jackmo's profile
2 posts in 908 days
09-27-2015 08:10 PM
Newbie here, nice site lots of info.
I live in MA.
I have a roof which is 4-12. it is 2×6 16 in. on center, 3/4 plywood sheathing
I just finished adding a second layer of asphalt shingles.
My question is are 2×6’s strong enough?
7 replies so far
View TheTurtleCarpenter's profile
1012 posts in 1000 days
#1 posted 09-27-2015 08:38 PM
That depends on how long the rafter lengths are and how they are braced/proped, or stiffened. The 3/4” ply is a plus. 2 layers of shingles in a Northern climate on a 4/12 pitch are going to give it a stress test for sure.
-- "Tying shoelaces was way harder than learning to Whistle",,,,,member MWTCA area K. Kentucky
View Ghidrah's profile
667 posts in 1157 days
#2 posted 09-27-2015 08:55 PM
Won’t stake my life on it. Ma. has been renovating its regs on roofing for close to 20 yrs, more and more towns are adopting the stricter 1 roof layer because of the older properties with undersized rafters. A 4 pitch is a shallow pitch, shear weight is directed down so if the structure is a ranch instead of a small narrow shed the rafts and ridge are going to see much sag in the near future, (5 to 7 yrs). If the rafts are trussed it’ll take maybe 30% longer but you’ll likely also see the sag transfer into the ceiling below.
You should have checked with your local building dept. before you did the overlay.
-- I meant to do that!
2 posts in 908 days
#3 posted 09-27-2015 11:29 PM
Thanks for the replies!
The rafter lengths are 11.5 ft.
A few have collar ties.
How about if I sister another 2×6?
View AandCstyle's profile
3005 posts in 2192 days
#4 posted 09-27-2015 11:48 PM
Jack, be sure to check for the snow load in your area; it can be significant.
-- Art
View bondogaposis's profile
4639 posts in 2286 days
#5 posted 09-28-2015 12:57 AM
Kind of late to ask that after putting the shingles on. From these tables it looks like you will be alright, based on 40 lb/sqft live load. If you get more snow than that, start shoveling.
-- Bondo Gaposis
View BurlyBob's profile
5304 posts in 2200 days
#6 posted 09-28-2015 01:07 AM
Bondo that was a good one. First the common sense, then positive reassurance then more confidence. Totally loved it.
View David Taylor's profile
David Taylor
326 posts in 1022 days
#7 posted 09-28-2015 01:35 AM
I just finished a shop building 20×20, with a 4:12 pitch roof in Southern NH. I saw those same tables, and used 2×8’s, 16 on center. Last winter was the worst on record and it was fine. I think 2×6 might be OK, but only just.
-- Learn Relentlessly
