Dowelmax Video Response to Woodworking Magazine Joinery Strength Testing
Forum topic by Dowelmax posted 11-27-2009 07:56 PM 4628 views 2 times favorited 29 replies Add to Favorites Watch
View Dowelmax's profile
Dowelmax
6 posts in 3073 days
11-27-2009 07:56 PM
Our latest joinery strength test in a series of three is available at the following link:
http://ca.video.yahoo.com/watch/6094394/15834754
The video is a response to an invalid joinery strength test published in a prominent woodworking magazine. This was our third series of tests, and the results were consistent with the first two.
-Mike, Dowelmax.
29 replies so far
117063 posts in 3543 days
#1 posted 11-27-2009 08:14 PM
Hey Mike
This is an interesting test an seems to prove dowels can be as strong as M&T joinery. I’m surprised because of
my thoughts has always been that dowel joinery was weaker. The one problem I see is that 4” dowels are not available on the the retail market that I’m aware of.
View papadan's profile
papadan
3584 posts in 3334 days
#2 posted 11-27-2009 08:18 PM
Nice demo Mike, I saw that test in the mag and stopped reading it when I saw the way they were doing it.
3809 posts in 3987 days
#3 posted 11-27-2009 08:42 PM
I’d be curious to know who wrote the magazine article?
Would it be bad protocols by the testers or advertising bias?
I think woodworkers have a right to know that.
View MedicKen's profile
MedicKen
1612 posts in 3428 days
#4 posted 11-27-2009 09:11 PM
I am curious, did the tenons and dowels break or did the glue joints fail as it appears?
View WhittleMeThis's profile
WhittleMeThis
125 posts in 3339 days
#5 posted 11-27-2009 09:33 PM
Certainly makes a reasonable argument for dowel joints. Would like to see a rebuttal from FWM.
TopamaxSurvivor
18247 posts in 3642 days
#6 posted 11-27-2009 11:04 PM
Looks like dowel joints should hold the fat lady until she is ready to sing :-))
16274 posts in 4184 days
#7 posted 11-27-2009 11:16 PM
I’ve always believed that dowel joints were plenty strong enough for furniture. Thanks for confirming.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3252 days
#8 posted 11-28-2009 12:39 AM
I’ve always had good luck with dowels. I take the magazine, and also watched on the web site. I had a problem then with the whole test and disagreed with some of the results based on my personal experience.
One issue I had was the type stress they put on the joints—come on, are furniture joints ever sterssed that way. The artical gave an unjustified bad name to certain joints and glorified others while not really comparing apples to apples.
Interesting test you just showed.
Thanks for sharing.
-- http://shepherdtoolandsupply.com/
TopamaxSurvivor
#9 posted 11-28-2009 12:50 AM
What mag was the report in?
View bigike's profile
bigike
4050 posts in 3254 days
#10 posted 11-28-2009 12:59 AM
i figure hey they all hold alot of weight so lets get back to furniture making and use what we think looks good on the piece were making.
View albut's profile
albut
56 posts in 3658 days
#11 posted 11-28-2009 01:12 AM
View cabinetmaster's profile
cabinetmaster
10874 posts in 3524 days
#12 posted 11-28-2009 01:28 AM
Wow. Very interesting video. That is fantastic proof that dowels work as good as or better than M&T.
#13 posted 11-28-2009 01:54 AM
Ken (Medicken) and I have been discussing this video a bit this afternoon and with Kens’ help I was able to get a glimpse of how the joints were tested in the articles we reviewed.
I found that there seems no consistancy with how the joints are set up in the instrument to test them.
They seem to be of random lengths and set randomly in the measuring device.
( I stand to be corrected here but those are my impressions.)
Without some standard measure as demonstrated by Mike, at Dowelmax it is impossible to draw any conclusions from the stress tests I reviewed.
I am putting my money on Dowemax right now as they beat conventional M&T by a wide margin.
Cheers
View DaleM's profile
DaleM
958 posts in 3350 days
#14 posted 11-28-2009 02:15 AM
There was no “winner” in this test IMHO. Two tenons were shown, with the higher one failing at 1010lbs. You only showed one dowel joint, which failed at 1020, barely any difference. Who’s to say if you tested another, it wouldn’t failed at 950lbs bringing the average strength lower than the M&T joint? Considering the test was conducted with someone who directly benefits from perceived better dowel performance, I don’t think I’m wrong to be skeptical. I’m just wondering why there wasn’t a second dowel joint test done is all, or if it was done, why wasn’t it shown? Having said all that, I don’t believe you intentionally misled by any means, and I’m impressed that the dowel joint did so well. I think it shows that either will do well on furniture and should hold up for years to come so it makes it a personal preference. You could say the dowel joint would be cheaper if you use expensive exotic woods and the dowels are cheaper than the length of wood needed to make the tenon.
-- Dale Manning, Carthage, NY
#15 posted 11-28-2009 02:16 AM
I think there are lots of ways to test a joint and lots of ways to make joints. My bad opinion of dowels comes from most of the repairs I’ve made in chairs and tables are results of broken dowels. Does this mean a dowel joint are bad? No but like all joints it has to do with how many dowels your using,how deep they are, what kind of wood there in, what kind of glue is used. I still think many joints are better than dowels. Most of us get use to doing things a certain way and stick with it, and consequently feel it’s the best way to go. I did notice there were a lot of dowels in the joint in the test . I wonder of those who use dowels would use that many and that long of dowels ?
showing 1 through 15 of 29 replies
