How to build the coolest cutting board ever
Forum topic by Woodtwerker posted 09-26-2015 07:13 PM 1989 views 0 times favorited 11 replies Add to Favorites Watch
View Woodtwerker's profile
Woodtwerker
21 posts in 851 days
09-26-2015 07:13 PM
I’ve been trying to make one of the “coolest cutting boards ever”. https://m.youtube.com/watch?v=lR9_CjQYZj4 but I can’t figure out how to cut a uniform 1/16” strip. I tried planer=It wouldn’t go that low. Tried the ripping on the bandsaw =it just left them to ridgid on the cut side. Tried table saw = very hard to get exactly 1/16”. Sometimes a little bit more, some times a little less. I noticed at min 1:20 in the video he used his planner but bent the board upward…is that what I need to do? How accurate to 5’16” does it need to be. Any help would be appreciated. Pic is for reference.
-- Gabe in Savannah
11 replies so far
View AlaskaGuy's profile
AlaskaGuy
3764 posts in 2179 days
#1 posted 09-26-2015 07:24 PM
Haven’t done this myself because I use a small wide belt sander for uniform thing strips but this might be worth a try.
http://theapprenticeandthejourneyman.com/2011/01/12/how-to-cut-uniform-thin-strips/
View MrUnix's profile
MrUnix
6188 posts in 2069 days
#2 posted 09-26-2015 07:55 PM
+1 on the thin rip jig like in the article above ^^^^^
And if you are like me, why pay $30 for a piece of plastic – when you can make one out of scrap wood and scrounged hardware pretty much for free :)
They can be used on either the table saw or band saw for cutting thin strips. You can also make really thin stock in most thickness planers by constructing an auxiliary table for it.
Woodtwerker
#3 posted 09-26-2015 08:45 PM
I tried the auxiliary table idea. A great idea until I got down just under 1/8. Then it would chew the maple up at the ends. I think at this point the cutting board gods have defeated me at this point. But I think I will probably be calling up rockler and getting that tool. Multiple reviews of fast simple cutting at 1/16”.
-- Gabe in Savannah
View SASmith               's profile
SASmith
1850 posts in 2857 days
#4 posted 09-26-2015 10:34 PM
Attach a thin strip to another thicker piece of wood with double-sided tape, then plane. 1/16” should be no problem.
-- Scott Smith, Southern Illinois
View Mike's profile
Mike
406 posts in 2557 days
#5 posted 09-26-2015 10:38 PM
I agree with Scott. Use double sided tape and attach it to a thicker board that has already been planed.
-- look Ma! I still got all eleven of my fingers! - http://www.lepelstatcrafts.etsy.com - https://www.youtube.com/channel/UCppWfrYGXCr5lm9uW-Fpqqw
AlaskaGuy
#6 posted 09-27-2015 09:36 AM
- Woodtwerker
Before you call Rockler watch some of these vids.
https://www.youtube.com/results?search_query=cutting+shin+strip+on+the+table+saw&page=&utm_source=opensearch
https://www.youtube.com/watch?v=ITRDUXbNfWY
View Tennessee's profile
Tennessee
2672 posts in 2385 days
#7 posted 09-27-2015 12:07 PM
+1 for Scott, but don’t use the padded double back sticky tape, use the thinner stuff that is used for putting on golf grips. Has a lighter tack and is easier to remove with just a bit of paint thinner, which releases the glue instead of prying off a thin strip of wood and breaking it up after the planing process.
View tomsteve's profile
tomsteve
701 posts in 1089 days
#8 posted 09-27-2015 12:42 PM
why not buy the 1/16” strips? quite a few places sell it.
Woodtwerker
#9 posted 09-27-2015 05:02 PM
Tomsteve the place near me charges a pretty penny for wood work. They have thin strips but pricey and are cut with band saw so they are rough. Closest other wood store is Jacksonville about 2 hours away.
Scott and Paul great idea. I’ll check out Walmart and see if they carry anything thinner and not as strong. I would never get that 1/16 off without breaking it.
Also thanks for the video links.
Thanks guys all great ideas, I’ll try them before I purchase.
Last question, how smooth should the strips be? I imagine planer smooth would be it, but would band saw work?
-- Gabe in Savannah
tomsteve
#10 posted 09-27-2015 10:11 PM
check out http://www.ocoochhardwoods.com/hardwood_veneers.php
ive gotten thin stock from them. its finish sanded and ready to use. good to deal with and good prices. good quality lumber,too.
you might even want to surf the www and see if theres any woodworking clubs in your area. could be a member nearby with a drum sander and/or can help ya find a sopplier near ya that isnt advertised.
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1447 days
#11 posted 09-28-2015 12:14 AM
I use veneer and pieces I cut, not sure if I got it 100% exactly the same size of router bit I used to cut the groove, but got it close enough.
