Storing Finishes
Forum topic by Jim Crockett (USN Retired) posted 11-26-2009 08:48 PM 1425 views 0 times favorited 6 replies Add to Favorites Watch
View Jim Crockett (USN Retired)'s profile
852 posts in 3877 days
11-26-2009 08:48 PM
How do you store your finishes, particularly varnish? The last three cans, I had to dispose of nearly half of a can of each because it had congealed. The last can of Arm-R-Seal, I even used Bloxygen but ran out and it gelled before I could get another can.
I really don’t want to buy in pints because it is so much more expensive (Qt – $14.99, Pint $11.99), but I suppose it would be cheaper than throwing half a quart out each time. Does anyone use additional containers to store your finish in smaller quantities – I am thinking of 8 oz. mason jars and dividing each quart into four 8 oz. containers. I did this with some Satin Arm-R-Seal, using 8 oz. poly bottles and it seems to be working – but filling the small neck bottles is a pain!!!
Any suggestions will be gladly accepted.
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
View Gary's profile
Gary
9352 posts in 3576 days
#1 posted 11-26-2009 09:21 PM
I’ve been wondering about getting dry nitrogyn in a bottle like what I have with my welding stuff, only smaller bottles, and using it like bloxygen. I do seperate some of the stuff into smaller bottles. I also put wax on the rims. Seems to help get the lid off…not my idea…someone told me to do it. I wish they would sell the stuff in collapsable bags with a small spout at the bottom. That would prevent the air from getting in there and allow you to use only what you want.
View SteveMI's profile
SteveMI
1120 posts in 3438 days
#2 posted 11-26-2009 09:21 PM
I had the same experience with the mason jar being unable to open.
I went to HD and they wanted $3 for an empty metal pint can. Would be nice to find an inexpensive source for the newer plastic pint cans.
Steve.
View Peter Oxley's profile
Peter Oxley
1426 posts in 4018 days
#3 posted 11-26-2009 09:25 PM
I’ve heard the suggestion of transfering the finish to a plastic container and then squeezing the container until the finish is just about to run over before putting the lid on – that way there is almost no air inside.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
27250 posts in 3966 days
#4 posted 11-26-2009 11:21 PM
Jim, all of the suggestions are on target. The main thing is to minimize the headspace on the finish when you close it up. Less headspace =less oxygen for the conversion process to continue. One other method for storing finishes that I use is, that since I largely use wiping varnishes, I cut the varnish 50:50 with mineral spirits. I have kept varnishes stored over a year without any noticeable jelling.
Rick Dennington
6164 posts in 3338 days
#5 posted 11-27-2009 02:16 AM
If you decide to use the mason jars to store your finish, here’s a suggestion, and one that I’ve used for years. Take the rubber seal (the one under the lid) off with a knife, small chizel, etc. Put a little dab (not much) of petroleum jelly on the threads, put the lid on, and screw and unscrew it a few times to spread the jelly on the threads. The r.s has a tendecy to get “mushy” and gummy. Once it’s gone, you should be ok.
Shake the jar pretty often, and keep it stirred. Hopefully it’ll last longer.
-- " It's a rat race out there, and the rats are winning....!!"
View End_Grain's profile
End_Grain
95 posts in 3281 days
#6 posted 11-27-2009 02:44 PM
Rick’s last sentence is on target. Whenever you reseal a can of anything, varnish, shellac, pvc glue, etc, shake the crap out of the can. This gets the humidity in the residual air in the can to 100% and generally prevents problems with whatever is in the can. A very old and dear shop teacher taught me this 35 years ago.
-- My greatest fear is that when I die, my wife will sell all my stuff for what I told her I bought it for.
