LN vs Lee Valley on block plane
Forum topic by frostwood posted 11-26-2009 08:56 AM 8045 views 0 times favorited 12 replies Add to Favorites Watch
View frostwood's profile
frostwood
38 posts in 3388 days
11-26-2009 08:56 AM
Specifically, I was interested on your opinions on the best value a of block plane. The two I have under consideration are: The Lee Valley Veritas Low Angle Block
Plane (05P22*1) for $139 vs
Low angle LN for $95 ON AMAZON.
THE VARATAS does have a mouth adjustment but I am not sure how much benefit that would be.
Thanks in advance for your opinion.
-- With each new day, celebrate life. Love God with all of your heart. Share Jesus with those around you and make a positive impact on those you meet. Bob
12 replies so far
View WayneC's profile
WayneC
13794 posts in 4298 days
#1 posted 11-26-2009 02:24 PM
Your compairing two different levels of planes…
The direct competitor for the LV plane is Lie-Nielson 60 1/2 . This plane is $165. I have the LN plane and it is a great plane. I have not used the LV Plane.
I belive the $81 LV Apron plane is the competitor for the LN plane (102i) that you have above.
The adjustable mouth planes are larger and very versatile. The smaller planes are very convient tools and designed for trimming and other tasks. Personally I would get an adjustable mouth block plane first then look to get an apron sized plane second. Though either would be a fine choice. It kind of depends on your planned usage and budget.
As far as manufacture goes. LV is less expensive and I would say the the workmanship on the LN planes is of higher quality. The question would be is the extra cost for the fit and finish worth it to you.
Here is a review of the LV planes by Alf
http://www.ukworkshop.co.uk/forums/viewtopic.php?t=1815
View Brian Havens's profile
Brian Havens
196 posts in 3307 days
#2 posted 11-30-2009 06:29 AM
Might I suggest restoring an old stanley plane? I find that they work every bit as good as a new plane and that the experience of restoring a plane is quite satisfying and educational.
I second Wayne on the adjustable mouth. The only exception is if the plane is to be used solely on end grain, but even in that case, the adjustable mouth does not hurt.
-- Brian Havens, Woodworker http://brianhavens.com
WayneC
#3 posted 11-30-2009 07:22 AM
Along the lines of what Brian was saying. You could look for an old stanley 9 1/2, 60 1/2, or 65 low angle block plane and tune it. Performance would be very good and if you wanted to kick it up a notch you could get a hock replacement blade…
Here is a Stanley 65 I found in an antique store for $25 along side my LN 60 1/2.
With Lie-Nielsen Plane
Brian Havens
#4 posted 11-30-2009 07:28 AM
Oh yeah, love the knuckle caps. (#18, #19, #65)
View Mike_Henderson's profile
Mike_Henderson
18 posts in 3308 days
#5 posted 11-30-2009 07:58 AM
Between the LN and the LV low angle block planes with adjustable mouths, I prefer the LN just because it fits my hand better. But then LV came out with a new line of low angle block planes and I haven’t been able to use one of those yet so my recommendation is not complete.
Regarding knuckle cap planes, I prefer the adjustment of a regular plane, for example, the LN 60 1/2. The reason is that it’s harder to adjust the knuckle cap plane. You have to keep trying to close the cap and then adjusting the screw until you get the right amount of pressure. Then, if you want to release the pressure to make a lateral adjustment, you pretty much have to completely release the pressure on the lever cap plane, while on the LN type plane you can loosen just enough to move the blade. When you go to tighten the lever cap again on the knuckle cap plane, you can have the blade move on you, causing you to have to go back and adjust again.
Be that as it may, I have a 65 that I use and like. It just looks trick. If you go to buy a 65, look carefully at the back sides of the mouth. You’ll often find cracks there where a previous owner forced the lever cap down too tightly and broke the bottom. The steel is very thin there and can be broken fairly easily.
Mike
WayneC
#6 posted 11-30-2009 08:15 AM
The veritas premium planes are real nice although they go for over $100 more than the LN adjustable mouth block plane. I played around with one at the woodworking show a couple of weeks ago.
http://www.leevalley.com/wood/page.aspx?c=2&p=61963&cat=1,41182,48942
View ondablade's profile
ondablade
105 posts in 3400 days
#7 posted 11-30-2009 06:24 PM
;-) I really hope Lee Valley are not headed down the collector/bling route….
ian
-- Late awakener....
View Walnut_Weasel's profile
Walnut_Weasel
360 posts in 3423 days
#8 posted 11-30-2009 06:37 PM
Frostwood,
Here is a link to a similar topic covered in the not-so-different past – most of the information on it looks similar to what has already been covered here.
-- James - www.walnutweasel.wordpress.com
frostwood
#9 posted 12-01-2009 01:30 AM
Thanks Walnut Weasel, That indeed was a good thread on the same subject.
View blackcherry's profile
blackcherry
3338 posts in 4024 days
#10 posted 12-01-2009 01:40 AM
My honest opinion is you just can’t go wrong with either one. Since I have both block plane in my collection I truly can’t say which one works better or out performs the other. Value is with the Veritas, other than that there great performers….Blkcherry
View Francisco Luna's profile
Francisco Luna
943 posts in 3594 days
#11 posted 12-01-2009 02:24 AM
Both are exseptional planes, Veritas is bigger (wider, heavier) has more attatchments / blades available, but I find LN much handy ~ better for use + classic look.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View Derek Cohen's profile
Derek Cohen
396 posts in 4170 days
#12 posted 12-03-2009 04:33 PM
http://www.inthewoodshop.com/ToolReviews/VeritasPremiumBlockPlane.html
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
