2001 era dovetail 8" jointer: set screws?
Forum topic by Holbs posted 09-25-2015 10:18 PM 664 views 0 times favorited 2 replies Add to Favorites Watch
View Holbs's profile
Holbs
1878 posts in 2056 days
09-25-2015 10:18 PM
Topic tags/keywords: geetech jointer 8 set screw table
What are the purpose of these 3 set screws w/locking nuts and the larger screw with handle? The operations manual for this jointer does not explain. I can reason they relate to the dovetail gib (so the tables slide up and down in a smooth non-sloppy fashion). If so, what purpose does the larger screw with handle serve? Locking the tables in place?
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
2 replies so far
View pintodeluxe's profile
pintodeluxe
5706 posts in 2840 days
#1 posted 09-25-2015 10:22 PM
Yes you are right, they take the slop out of the dovetail way.
The handled knob locks it in place.
Some jointers use a knob as a maximum depth of cut stop. Your version looks more like a simple lock to prevent you from inadvertently changing the depth of cut setting.
Holbs
#2 posted 09-25-2015 10:31 PM
Thanks pinto… iIwas guessing the same, but the spacing between the 3 set screws and t-handle confused me. The only gibs I have worked on have been for cutterheads and they are spaced evenly. These are not.
