Are all #2 live centers compatible with a lathe #2?
« back to Woodturning forum
Forum topic by toddbeaulieu posted 09-25-2015 09:22 PM 1529 views 0 times favorited 11 replies Add to Favorites Watch
View toddbeaulieu's profile
toddbeaulieu
814 posts in 3003 days
09-25-2015 09:22 PM
Topic tags/keywords: lathe live center oneway
Sorry if this is a stupid question. My PM #90 takes a #2 morse taper live center. I have crappy centers with no bearings and want to upgrade. Looking at the Oneway system which seems pretty nice.
Will it definitely fit since they’re both #2? Or are there different diameters that are still considered #2, requiring me to dig deeper to find out if it will fit?
Thank you.
11 replies so far
View TheDane's profile
TheDane
5423 posts in 3662 days
#1 posted 09-25-2015 09:59 PM
A #2 Morse Taper is a #2 Morse Taper … I have had good luck with the Woodtek Live Center from Woodworker’s Supply …
http://woodworker.com/woodtek-live-center-2mt-mssu-159-164.asp?search=live%20center&searchmode=2 . They run $20 or more cheaper than competitive products and are very high quality. I have one of them in my shop, and our turning club has eight PM3520B’s equipped with them.
View LeeMills's profile
LeeMills
543 posts in 1300 days
#2 posted 09-25-2015 10:51 PM
Both the Oneway and Woodtek are very good as far as I know.
I have the Nova and it is 2MT.
The Miniature Extension is good if you are wanting the tailstock back for the work more.
The Threaded Center and the Hollow Cup & Point are also 2MT which means you can use them in the headstock. The Hollow Cup & Point as a “Safety Center” and the Threaded Center with your customization as a drive center.
The Nova is also three sets of bearings instead of two.
http://www.tools-plus.com/nova-lathes-5015.html
I may be wrong but I believe the Oneway and the Woodteck can also be used in the headstock when you lock it with a pin. But then what do you do for a live center in the tailstock? Buy another?
Using the Threaded Center in the headstock the rest of the live center can be used in the tailstock with the Nova.
The OW and the WT can be used with custom centers but you have to drill and tap for the 3/4 X10.
With the Nova I use tee nuts. Drill for the tee nut shaft and drive it in. In the future is steel against steel.
This shows the Threaded Center in the headstock used as a friction drive. The smaller rubber ball in the second pic is just right for candle sticks, etc.
Just some of the centers.
TheDane
#3 posted 09-25-2015 11:27 PM
One thing I should mention … though a #2MT is a #2MT, the tapered shafts on tools made for mini and midi lathes are often shorter than those made for full-sized lathes (this is due to the shorter quill travel on mini/midi machines).
One of our students was using a live center from a Delta midi on one of our Powermatics, and the self-eject wouldn’t work on the PM tailstock. All a knock-out bar would do was drive the spur out, which meant our lab technician had to do surgery to extract the Delta live center from the tailstock.
The Woodtek live centers (as well as the OneWay and Powermatic) have longer shafts and will work in any #2MT machine.
toddbeaulieu
#4 posted 09-26-2015 12:48 AM
I have these three mentioned items in my wish list for consideration.
I need to absorb all this. I’m trying to buy things before I have any idea what they even are. I’m sure that I’ll laugh about how ignorant I was in very short order. The OW is quite a bit more $ than the other two. Almost double the Nova.
Thanks guys!
LeeMills
#5 posted 09-26-2015 12:36 PM
If you have a dead cup center for the tailstock don’t get rid of it.
It becomes a safety center or ring center in the headstock worth $20-25.
Mike Peace does an excellent job on almost every holding method (about 1.5 hours).
IMHO he does give the steb center a little too much praise but it is a great center for some situations (that is my only nit-pick)
https://www.youtube.com/watch?v=aUXil-5dEeo
toddbeaulieu
#6 posted 09-27-2015 11:55 AM
I screwed up by mentioning the live center in my chuck thread and this conversation is now fragmented.
@Lee, started watching the Pearce video. Thank you, it’s PERFECT for me. I’ll have to finish later as I have to head out to treat my golfing withdrawals.
I believe that what came with my lathe is indeed the “dead cup center” or safety center, as seen at 16:00.
@The Dane recommends the Wodtek center, which is similar in appearance to the Oneway that I had mentioned. What confuses me is all the discussion about $10 centers, when I’m considering a $120 center. Makes me think either we’re not talking about the same thing or I’m about to waste my money on something that I don’t need.
I do like that Steb center because all I have are 2 and 4 drive spurs. I love the idea of being able to stop the piece, especially because my #90 have the big crank lever, which is not ideal for frequent starts/stops.
TheDane
#7 posted 09-27-2015 12:36 PM
You need a live center (e.g. a center with bearings) for the tailstock. Some live centers (e.g. the Woodtek) come with accessories, while the cheap ones do not. If you find a live center for $10, run the other way … it probably isn’t worth buying.
A dead center (ring, safety, steb, spur, etc.) goes in the headstock. They are considerably cheaper.
... I have to head out to treat my golfing withdrawals.
Keep your head down and hit’em straight.
View Nubsnstubs's profile
Nubsnstubs
1287 posts in 1729 days
#8 posted 09-27-2015 02:29 PM
Todd, I made 17 live centers that if I were to try and sell them, the price would have to be near $700 in order to make a profit. Of course, they wouldn’t sell at all to the woodturning community, so I gave up on that.
The $10 centers are probably dead centers that in my opinion are a takeoff from the tailstock holding point/cup from the treadle lathe days, and are still with us today. I have one, and it just sits in it’s place on my tailstock accessory rack.
A MT2 has a standard dimension of, 1.48°( not absolutely positive of that angle) with .700” OD at the large end, .572” at the small end on a 2.5” length. No matter where in the world you go, those dims are used to make a MT2 tapered item, whether female or male…........ Jerry (in Tucson)
LeeMills
#9 posted 09-27-2015 04:24 PM
Terminology can get confusing as to centers.
Others may well disagree with me and that is fine.
A Dead Center is used in the tailstock and does not revolve (have bearings). This would be like the $4 center I posted a link to at ebay. This is an old style due to no bearings and turners would often add a bit of wax or oil to the tip to keep it from burning the wood as the wood rotated. The Dead Center is normally just a point, or a ring, or a cup & point. The Ring center is typically hollow to allow you to pass a drill bit through it such as in drilling for a lamp. The Cup & Point may or may not have a removable point.
A Live Center is used in the tailstock and varies in price due to quality and adaptability. It will have bearings (either 1, 2, or 3) and rotate with the work. Most new lathes come with a one bearing live center. Below is a link to the Nova standard equipment live center. I had a one bearing in my old jet and used it for 25 years with no problems at all. http://www.tools-plus.com/nova-lathes-2mtlc.html
A Drive Center is used in the headstock to of course, drive the work.
This may be a four-prong center, a two-prong center, or a steb center (these are the three most common).
To confuse things….. remember that Cup & Point from the tailstock? It can be moved to the headstock as a Drive Center. It does not bite into the wood like a prong or steb but relies on friction alone.
Adding more pressure from the tailstock increases the amount of drive.
I believe it was Alan Lacer who made it popular for folks starting out because if you had a catch the wood would stop spinning instead of coming off of the lathe. Since the wood stopped spinning Alan called it a Safety Center. I did buy a couple of the $4 ones and I do think it helped my daughter to not be as afraid of the lathe. I used mine a few times but once you learn the tools and how to not get a catch they are more of a pain than they are worth IMHO. A drawback is because it relies on pressure from the tailstock, a small diameter spindle may flex (bow) under the pressure. Seems to work well for tool handles or other stout work.
I know this is OT to your original question of Morse tapers but my use of terminology seems to differ from others.
View Wildwood's profile
Wildwood
2305 posts in 2133 days
#10 posted 09-27-2015 04:33 PM
Here is a MT chart but doesn’t take into account mini, midi, or full size lathes. Anyone of centers listed should work well with PM 90.
http://www.drill-hq.com/2012/04/morse-taper-dimensions-chart/
Oneway live center
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=packard&Category_Code=lathes-acc-cent-revtail-olc
Hold Fast
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=packard&Product_Code=110977&Category_Code=lathes-acc-cent-revtail-hflivcenad
Nova
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=packard&Category_Code=lathes-acc-cent-revtail-nova
Live Center that came with my Jet called Oneway clone and which looks lot like Woodtek Center, Dane likes. Well still use my simple $30, G1293 from Grizzly bought over twenty years ago. Started using it on a Delta 700, Jet Mini, and now my Jet 1642. OEM center collects dust mostly. Still use a dead center for tuning pens when turning between centers although mount the dead center in the head
Goood luck with it!
-- Bill
toddbeaulieu
#11 posted 09-28-2015 01:26 PM
Thanks everyone. So much wonderful insight.
I ordered the Oneway live center this morning. I almost went with one of the less expensive offerings to leave more $ for other tools, but decided to splurge, assuming that the Oneway will be fantastic. While I don’t intend to turn pens I got the pen center add-on, for the heck of it.
I also decided to order a spur drive to try. I went with the $20 PSI unit.
