Pros and cons of two type of table saw
Forum topic by tamtum posted 09-25-2015 08:15 PM 1920 views 0 times favorited 8 replies Add to Favorites Watch
View tamtum's profile
tamtum
197 posts in 1808 days
09-25-2015 08:15 PM
Topic tags/keywords: question
Lately I am in search of circular saw bench. Beyond the brand I have seen the following types of tables. Can anyone tell me their differences, the pros and cons and of course if someone has worked in Type 1 I would like a review of this type. I have read sites like http://www.rockler.com/how-to/table-shop/ but I cannot find reasons to buy type 1 or 2.
Thanks in advance.
-- Alexander , Greece, http://alekosbiki.wordpress.com/
8 replies so far
View MT_Stringer's profile
MT_Stringer
3160 posts in 3199 days
#1 posted 09-25-2015 08:42 PM
Those saws are kinda small. OK if you want to work with small stuff.
Here are my two. Big difference. Grizzly 1023 and DeWalt DWE7480
I use the little DeWalt for cutting trim and filler strips on location.
My sweetie was hooking up the 2 1/2 inch dust collection hose. Easy fit.
DWE7480
It has a short arbor – dado stack won’t fit. I did manage to use two 7 1/4 inch circular saw blades and a shim to cut the grooves for 17 drawer bottoms. Worked great.
The saw is loud, but at 45#, it is easy to haul around, and it stores neatly when mounted on it’s stand.
Sorry, that’s all I can offer. I have never heard of the saws you posted.
tamtum
#2 posted 09-25-2015 08:53 PM
Thanks Mike , Grizzly 1023 is a dream. I have limited space. In Greece DeWalt as I know haven’t the best after sale sevice. Metabo is German and have motors 3,1 kW type 1 and 2KW the type 2. The table are small but for my space is ok. My problem is why someone choose type 1 or type 2.
View MrRon's profile
MrRon
4720 posts in 3212 days
#3 posted 09-25-2015 09:02 PM
The type 1 is a portable hand held saw mounted in a table. The saw can be removed for hand held cutting. The type 2 saw is a job site saw that can only be used as shown. The type 1 is more versatile and probably costs more than the type 2.
tamtum
#4 posted 09-25-2015 09:20 PM
MrRon thanks , the spec of each type are above. In fact type 1 is cheaper.
Type 1 : METABO TKHS 315 M – 3,1 WNB and cost 570 euro
Dimensions1700×700 x 1000 mm / 5.6×2.3×3.3 ft
Support surface800×600 mm / 31 1/2×23 5/8 ” mm
Working height850 mm / 33 1/2 ”
Cutting height0 – 85 mm // 0 – 3 5/16 ”
Maximum cutting height 90/45°85 / 53 mm // 3 5/16 / 2 1/16 ”
Maximum cutting width at parallel guide/rip fence340 mm / 13 3/8 ”
Maximum material width at mitre fence250 mm / 9 13/16 ”
No-Load Speed2990 /min
Max. cutting speed50 m/s / 164 ft/s
Saw blade315×30 mm / 12 3/8×1.181 ”
Saw blade swivel range0 – 45 °
Rated input power3.1 kW
Output power2.2 kW
Weight75 kg / 165 lbs
Type 2 : METABO TS 250 and cost 770 euro
Motor Input: 2.0kW (230 volt model), 1.55kW (110 volt model)
No Load Speed: 3950 rpm (230 volt), 3900 (110 volt)
Blade Diameter: 250mm
Blade Bore: 30mm
Kerf Width: 2.8mm
Depth of Cut: 77mm (90 degrees), 51mm (45 degrees)
Machine Weight: 32kg
View Hinge's profile
Hinge
79 posts in 1656 days
#5 posted 09-25-2015 10:02 PM
Mike, when you store the saw on end as in your picture doesn’t the oil or gas leak out?
-- The Jesus is my Savior
MT_Stringer
#6 posted 09-25-2015 10:57 PM
Mike, when you store the saw on end as in your picture doesn t the oil or gas leak out?
- Hinge
There is nothing to leak out. Well maybe some sawdust. :-)
View AlaskaGuy's profile
AlaskaGuy
4050 posts in 2277 days
#7 posted 09-26-2015 01:54 AM
- Hinge
The oil in those saws are a very special type. When the saw is in use (horizontal) the oil is very thing and does it’s job. But, as soon as you turn the saw vertical the oil instantly turns to a heavy grease and stays put.
Hope that helps.
View RobS888's profile
RobS888
2406 posts in 1813 days
#8 posted 09-26-2015 02:03 AM
Oh, I read about that “positional viscosity” very trick.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
