Bentwood Ring Advice
Forum topic by DavidJohnHand posted 09-24-2015 08:21 PM 793 views 0 times favorited 1 reply Add to Favorites Watch
View DavidJohnHand's profile
DavidJohnHand
10 posts in 904 days
09-24-2015 08:21 PM
I’ve noticed I’ve been having a problem with my bentwood rings, I sand both tips down as they should be etch but when the rings are coiled and held together then cleaned up I’ve noticed a certain area on the rings are either too thin or too thick on the band, how can I combat this?
1 reply so far
View mahdee's profile
mahdee
3843 posts in 1671 days
#1 posted 09-24-2015 08:25 PM
Best way to do that is to use two different color wood and intentionally sand the sides to show the contrast. On the surface, if the contrasting color show up, thin (taper) that section of the ring to serve as the bottom.
-- earthartandfoods.com
