Small Hinge Screws for 1/8th inch stock?
Forum topic by gn1weirdness posted 09-24-2015 12:02 AM 790 views 0 times favorited 7 replies Add to Favorites Watch
View gn1weirdness's profile
gn1weirdness
15 posts in 917 days
09-24-2015 12:02 AM
Hopefully I have this in the right forum, if not please let me know.
My question is, does anyone know of any hinge screws, or micro hinges I could use on a very small box lid that I have made out of 1/8th inch stock?
Thank you a ton in advance.
7 replies so far
View crank49's profile
crank49
4029 posts in 2876 days
#1 posted 09-24-2015 12:18 AM
No, actually it should go in the RIGHT forum, or perhaps more gramatically correct, I should say the correct forum.
View gfadvm's profile
gfadvm
14940 posts in 2595 days
#2 posted 09-24-2015 12:30 AM
I would probably forego the screws and glue with epoxy.
View Jim Finn's profile
Jim Finn
2622 posts in 2827 days
#3 posted 09-24-2015 12:58 AM
Yes glue them in place. Look for “aileron hinges for radio controlled model airplanes”. The shortest screws I have found are 1/4” long.
gn1weirdness
#4 posted 09-24-2015 01:00 AM
- crank49
That was BAD lol, like REALLY REALLY BAD. Grammatically has two m’s by the way :: ) Either way well played, and thank you everyone for the info so far. Really appreciate it, I also was unable to find anything for these purposes smaller than 1/4th, unless you get into machine screws for computer/tech work.
View Hinge's profile
Hinge
79 posts in 1593 days
#5 posted 09-24-2015 04:49 AM
The couple times I have used 1/8” stock to build a box I have drilled holes through the stock, mounted the screws, cut off the tips, sanded to 1000 grit and ended up with two shiny little dots (design statement).
-- The Jesus is my Savior
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2275 days
#6 posted 09-24-2015 12:51 PM
I assuming it’s too late, or doesn’t fit the aesthetic, to glue an additional support strip under the back edge? Would provide a bit more bite, or possible allow you to drill holes in the end of said strip, and use small brass rod or dowels on the ends as a hinge.
gn1weirdness
#7 posted 09-24-2015 05:33 PM
Never to late. I was thinking of doing that honestly. I am also toying with some other ideas that I have never seen anyone do before and would add some serious internal aesthetic to each piece as well. It would also actually be easier than using hinges, well if it works out.
