Delta 36-725 - Lowes
Forum topic by wep posted 09-23-2015 02:47 PM 918 views 0 times favorited 7 replies Add to Favorites Watch
View wep's profile
wep
22 posts in 1051 days
09-23-2015 02:47 PM
Well, I finally spent my money. Ebates had 4% cash back, along with my 5% cash back on Discover, I spent the $597 and bought the saw! About time, I already bought the dado blade and a ridge carbide full kerf blade.
Began the set up. Legs went on fine, the plates / braces for the legs not so much. The two shorter ones (now they use phillips head self taping) fit perfectly, the two longer ones are not quite long enough, need to be redrilled. Got it rolled into the garage. Couple days later pulled the plastic off to clean the top, RUST! It had stained the plastic in several spots, not much coating of anything on the cast iron. Scrubbed the rust spots, pitted.
Contacted Delta, they said return it and get another one. Of course I got rid of the two huge hunks of styrofoam already ( I should have waited). Loaded it with all its bits into the trailer and back to Lowes.
Lowes does not do simple exchanges, it is a return and sale. Normally not an issue, but I would have lost the Ebates 4%. Not the clerks problem, but I needed a manager. Manager came, I explained about the 4%, he said, OK, I will take 5% off the sale of the replacement. Outstanding! They brought me out my new saw, and took my partially assembled saw.
If the rust that had happened was due to my neglect (which will probably happen at some future point) I could live with it ( it was not much, several patchy spots over several square inches) – just did not want to start out that way! Lowes was wonderful.
Have not started the set up on the new one yet (nor have I opened it to look at the top – they are in the box upside down). Sunday maybe.
-- Never try to teach a pig to sing. It wastes time and annoys the pig. - Robert Heinlein
7 replies so far
View Clarkie's profile
Clarkie
450 posts in 1715 days
#1 posted 09-23-2015 03:50 PM
Perhaps you should have checked the new saw top while at Loew’s just a thought.
View natgas's profile
natgas
5 posts in 862 days
#2 posted 09-23-2015 03:50 PM
You will really enjoy it; I’ve had several different TS and this is my favorite by far. Still have a lot to learn
-- Randy
View Stewbot's profile
Stewbot
199 posts in 958 days
#3 posted 09-23-2015 04:12 PM
Wep,
Do you know what the factory warranty on that saw is? Is it 5 year? I’m just curious.
-- Hoopty scoop?
View wep's profile
wep
#4 posted 09-23-2015 04:32 PM
We thought about checking the top in the store, but decided, given the packaging it would be a bit of a pain, to then have to button it to go home again.
Yes, it has a 5 year warranty.
View hotbyte's profile
hotbyte
989 posts in 2849 days
#5 posted 09-23-2015 07:08 PM
Were the bolts on the legs and short braces still loose when you tried to put in bolts for long brace? If left loose, they give you some wiggle room.
Bummer on the rust. Mine was rust free new but has some spots already from use (and dummy me setting a glass on water on it ARRGGGHHHH ).
View SuperCubber's profile
SuperCubber
1015 posts in 2158 days
#6 posted 09-23-2015 07:31 PM
Congrats on the saw! You’re going to be very happy with it. Hopefully this assembly goes a little better.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View wep's profile
wep
#7 posted 09-23-2015 08:32 PM
- hotbyte
I think I had snugged them up, I will take your advice and leave everything looser. Thanks.
