Veritas® Scraping Plane Insert ?
Forum topic by John Gray posted 11-24-2009 06:18 AM 3289 views 1 time favorited 7 replies Add to Favorites Watch
View John Gray's profile
John Gray
2370 posts in 3882 days
11-24-2009 06:18 AM
Topic tags/keywords: plane question finishing milling
Has anyone used or do you own this Veritas® Scraping Plane Insert?
If so would you please comment. I’ve got a $40.00 gift card for Lee Valley and it’s burning a hole in my pocket. 8^))
http://www.leevalley.com/wood/page.aspx?c=2&cat=1,310&p=32635
7 replies so far
View Moron's profile
Moron
5032 posts in 3890 days
#1 posted 11-24-2009 06:42 AM
it reminds me of Air Canada…...........and their moto
We will not be happy till your unhappy and I hope LV will abondon such nonsense
what the %$ck is that?
View WayneC's profile
WayneC
13754 posts in 4094 days
#2 posted 11-24-2009 07:12 AM
You might ask Alf. She has reviewed most of LV’s planes for the
British woodworking forums. Send her a PM.
http://www.cornishworkshop.co.uk/combinationplanes.html
Someone was making a high end version of this. I belive they were designed for a #7.
WayneC
#3 posted 11-24-2009 07:16 AM
I found what I remembered… Here you go
http://blogs.popularwoodworking.com/editorsblog/Convert+A+Handplane+Into+A+Scraper+Plane+With+New+Custom+Tooling.aspx
This may be interesting as well
http://www.sawmillcreek.org/showthread.php?t=47858
View Brian Havens's profile
Brian Havens
196 posts in 3103 days
#4 posted 11-24-2009 08:15 AM
I have one of these. It is just OK. If you do not have a some experience with scrapers and scraper planes, I am not sure I would recommend it. I much prefer my #112 Stanley or the wooden scraper planes that I made in the shop. I have not published photos of my full size scraper planes, but I have pics of a couple of mini scaper planes here...
I also find that adding a wooden sole to a #80, with a relief behind the scraper blade improves performance a lot.
-- Brian Havens, Woodworker http://brianhavens.com
WayneC
#5 posted 11-24-2009 08:20 AM
Here is a photo of the #112 I picked up last Friday. It did not have a blade when I got it. So I ordered a hock blade for it.
DSCN0243
DSCN0242
This is what I am jonesing for at LV
http://www.leevalley.com/wood/page.aspx?c=2&p=64300&cat=1,230,41182
Brian Havens
#6 posted 11-24-2009 08:52 PM
I used the largest scraper from this set as a replacement for my #112. I just had to trim a little off the width to make it fit. I prefer a thinner blade for scraper blades because I find that the small amount of flexibility tends to eliminate chatter. I also do not use a 45 degree bevel, but rather a squared edge just like a regular card scraper. I find it less aggressive and since I use my #112 closer to final finish, I find it appropriate.
My 2 cents worth.
WayneC
#7 posted 11-24-2009 09:01 PM
Great tip Brian. Also less expensive.
