Caster advice, please
Forum topic by sikrap posted 11-24-2009 06:16 AM 7206 views 2 times favorited 22 replies Add to Favorites Watch
View sikrap's profile
sikrap
1121 posts in 3601 days
11-24-2009 06:16 AM
Well, I’m finally getting started on building stuff to outfit the new shop. My first priorities are a bench, router table and drill press stand. I’ll be putting casters on and have a two questions. First, where is the best place to buy them? I’ve found that Hartville Tools has the lowest price, but it will still cost about $40 per set if I use two locking and two fixed. That leads to the second question. Is that the proper configuration or should I use two locking and two swivel? Thanks!!
-- Dave, Colonie, NY
22 replies so far
View Peter Oxley's profile
Peter Oxley
1426 posts in 4116 days
#1 posted 11-24-2009 06:25 AM
I use two fixed and two locking swivels on just about everything. If you use two locking swivels and two swivels, your machine will still move quite a bit as the swivels will still turn even when the wheels are locked. There are some higher end casters that lock the wheel and the swivel, but I’ve found that it’s hard to guide a tool where you want it to go with four swivels – they tend to wander around.
Grizzly has decent prices on casters, but I haven’t compared them to Hartville.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View russv's profile
russv
262 posts in 3411 days
#2 posted 11-24-2009 07:02 AM
Dave,
I work for Payson casters in Il. So what I know about casters is extensive. First, as to the caster configuration. you hace several choices. go to http://www.paysoncasters.com/mounting.htm and you can see some of these caster configs. I use the 4 swivel config mostly because of the ease of direction I can go. sometimes this is not practical when you want to control direction. If you are going to put casters on multi items, buy 3 or 4 sets (swivels and rigids) and try it with all swivels and then try some with 2 of each. if you want you can put the rigids in the center side to side one swivel on each end to get good turning. this allows turning on a dime like a material cart in a home center. make sure all casters are the same height to avoid the teetering and all casters always touch the floor. you ask me questions and i will answer your questions.
where to buy, go to http://www.castershop.com . $20-25$ for a set (4) of medium duty casters and the heavy duty are very cheap compared to most places. I use these caster in my shop and they work great. if you need help determining which size and wheel type, let me know and i will explain the advatages of each type for you.
if you need a specialtype for something special, I can help you get them though Payson. Send me a private PM to discuss this.
russv
-- yknotwood.com: where to go because you don't want no stinking plastic!
View Moron's profile
Moron
5032 posts in 4135 days
#3 posted 11-24-2009 07:06 AM
All wheels on my carts move in all directions
fixed wheels really suck!!!!!
any one who disagrees…...............hasnt spent enough time pushing and pulling a cart around
View ADKAmateur's profile
ADKAmateur
9 posts in 3369 days
#4 posted 11-24-2009 07:11 AM
I have casters on a lot of my shop furniture (clamp rack, two work tables, and a storage cabinet). I agree with Roman – after learning the hard way with the storage cabinet that has two fixed and two swivel, I went with all swivel on the rest. I also use locking casters on all corners – don’t know if it matters, but it seems to lock my assembly table down quite nicely – as if it wasn’t on casters. The casters I now use exclusively are the red, higher quality 3” or 4” casters. These roll so much easier than the black or gray casters.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3425 days
#5 posted 11-24-2009 07:19 AM
That depends on the weight of the item on the casters. We have engine stands that did have casters on all 4 corners and once the mass starts moving its hard to steer. My tool box wouldn’t be managable with all casters.
russv! Do urethane wheels hold up or do you prefer hard rubber wheels?
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
russv
#6 posted 11-24-2009 07:35 AM
retired…,
i prefer poly wheel. they are less likely to get a flat spot and roll easier.
ADKA…,
the bigger the wheel, the easier it rolls. the wider the wheel, the more weight it will carry. this is a generalization, but a good rule of thumb. as to locking, you can get a wheel lock or a total lock whick locks both the swivel and the wheel. again, what you are using them are might determine which to use. wheel lock only is cheaper and most of the time good enough.
i like using 4” or 6” wheel, depending on size and weight of the cabinet. locks on all wheel is better because i usually only lock 2 wheels but sometimes that’s all you can get to easily.
russv
russv
#7 posted 11-24-2009 07:44 AM
one more thought. on ocassions, you can put just 2 wheels on one end and handles on the other end and move it like a wheel barrow. this is alot cheaper than 4 casters and stays in place pretty much.
if you look at my homepage at my tablesaw, i used 4 swivels and put a lever on the casters to lift them up and down. this lets me move it easily and i can drop it down on levelers to level it. i used 4 total locking casters on my workbench it does ok, but i think i am going to change that to lifting caster and levelers.
russv
View Gene Howe's profile
Gene Howe
11168 posts in 3670 days
#8 posted 11-24-2009 03:51 PM
I modified my lunch box planer stand for two casters in front. I just tip it toward me and roll it around. But, be careful with other tools. I built a stand for a thickness sander, put on two wheels and handles. Built the base just wide and deep enough for the sander (first mistake), and didn’t bolt down the sander (2nd mistake).
First time I picked it up to move it, the sander fell off!!
I learned from that!
Gene
russv
#9 posted 11-24-2009 03:54 PM
wow, we both learned from your mistakes, thanks for going first. lol
hope it didn’t fall on your toes.
I never thought of your wheel placement, i like that idea.
russv
sikrap
#10 posted 11-24-2009 04:25 PM
Thanks everyone!! I will be using two locking swivel and two fixed. I have decided to go with the ones from Hartville because they are the least expensive and they are 100% guaranteed. I will be using 3 inch for the drill press stand and router table,but 4 inch for the workbench. Thanks again.
Moron
#11 posted 11-24-2009 05:14 PM
I sometimes visit my old bosses shop and shoot the $!it with the guys. The shop is about 10,000 sq ft and has carts and dollies galore. The only carts that never get used are the ones with 2 fixed wheels.
I remember a cart in a shop with inexpensive guarenteed wheels on it. With couple hundred pounds of expensive product on top the cart wheel hit a small wood chip and stopped suddenly while all the expensive parts continued on their way…...........52 pick up and lots of money down the drain.
I think its worth every dime spent on a castor that turns over extension cords, wood chips etc. The smaller the shop, the easierit is to move carts when ALL the wheels turn. Kinda like parrallell parking a car….....sometimes the car just wont fit into the opening cause two wheels are fixed.
View Jim Crockett (USN Retired)'s profile
852 posts in 3975 days
#12 posted 11-24-2009 08:14 PM
Nice discussion of casters. I’ve been thinking of adding casters to my drill press table and this helps. One things that was not mentioned – I believe the weight rating for casters is for each, right? In other words, if you have 4 200 lb rated casters, the total rated load is 800 lbs?
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
russv
#13 posted 11-24-2009 11:47 PM
jim c,
that is correct, the rating is not the failure point either. the cart won’t crash at 801 lbs. the rating is a guide line for best capacity to and still work well. you can put a 1000 lbs on it but it will only roll around like crap and wear out sooner.
russv
View DaneJ's profile
DaneJ
56 posts in 3450 days
#14 posted 11-25-2009 12:46 AM
I prefer 4 swivel casters with double lock. I have some tool rollers with 2 fixed wheels and 2 casters and spend more time and effort going back and forth across the floor to get it in the right place in the shop(I think the official term is the “tool cha-cha-cha”). 4” poly casters roll well and a wood shaving will not jam it.
I wished I could find a double lock that the lock lever is in a fixed location on the base(top) not on the trailing side of the caster, anybody?
-- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away... Tom Waits
russv
#15 posted 11-25-2009 01:37 AM
dane,
physically impossible. to make contact to the tread to lock down the brake pad needs to stay in alignment with the wheel tread. if the wheel swivel, that will be in any direction you are going
dave,
I don’t get it. the casters on www.castershop.com are $4-$5 cheaper each than Hartville when you compare same size and capacity.
russv
