Trying to wrap my head around this nightstand
Forum topic by LiveEdge posted 09-22-2015 09:13 PM 1003 views 2 times favorited 8 replies Add to Favorites Watch
View LiveEdge's profile
LiveEdge
571 posts in 1523 days
09-22-2015 09:13 PM
Topic tags/keywords: question
I came across this nightstand from someone here that doesn’t seem to be too active. In trying to pencil out some plans, I’m having trouble with the panels and the fact there are panels in both the vertical and horizonal dimension. Is this inevitably going to lead to blind dados (or rabbets) which I can do, but are extra work and I wondered if I’m just not thinking about things clearly. Am I better off using stripping in some locations for the lighter wood?
How about the joints in general? If you have four horizontal rings for each level, do you think it’s just butt joints for the spacer sections? Seems like there might be a better way to do it.
8 replies so far
View mahdee's profile
mahdee
3843 posts in 1670 days
#1 posted 09-23-2015 12:00 AM
It looks like a cabinet material or possibly wood (depending on the size) with the lighter (oak wood) as a trim.
-- earthartandfoods.com
View BurlyBob's profile
BurlyBob
5239 posts in 2168 days
#2 posted 09-23-2015 12:28 AM
That looks really cool. It has the look of Campaign furniture or a steamer trunk. I really like it. I’m thinking I’m going to hang on to this for future reference.
View Pezking7p's profile
Pezking7p
3217 posts in 1554 days
#3 posted 09-23-2015 01:02 AM
Think of it like two side panels where the top and bottom rails are also part of a top and bottom panel. I’m sure the back is frame and panel as well. The only blind dados would be for the drawer frames, if there are any.
-- -Dan
View Texcaster's profile
Texcaster
1271 posts in 1576 days
#4 posted 09-23-2015 02:15 AM
How about a link to the original page and more photos ?
-- Mama calls me Texcaster but my real name is Mr. Earl.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1477 days
#5 posted 09-23-2015 04:19 AM
frame and panel,with in-layed drawer fronts,and the metal is to give it the steamer trunk look just decoration. Could also be built as a panel carcass then the Frame added as trim.
LiveEdge
#6 posted 09-23-2015 05:04 AM
Texcaster, there is a link in the original post, but unfortunately that’s the only picture.
LiveEdge
#7 posted 09-23-2015 05:07 AM
So what I’m trying to decide is whether it is better to have the “trim” sections (the light wood) provide the strength of the body with the dark sections being floating panels, or have the dark sections provide the strength of the box and the light sections are just a trim overlay.
View bandit571's profile
bandit571
19157 posts in 2586 days
#8 posted 09-23-2015 01:33 PM
Make frames with the Oak. The panels of darker wood can fit into grooves in the frames, using a rebate around the edges. Almost like the Shakers used.
Looks like some areas of oak are a bit thicker? Joints can just be mortise & tenon. Top and bottom F & P sections can be seperate units. Glued in place, pocket screwed from the inside, or just some dowels to line things up..
Boss has seen this thing, and likes it…...means trouble brewing in the Dungeon Shop…
