Forum topic by micnasty | posted 11-24-2009 01:12 AM | 4990 views | 0 times favorited | 18 replies | ![]() |
Topic tags/keywords: broken 10 delta tablesaw question i recently was given a tablesaw from some one i was doing a side job for. its an old 10” delta, all metal. |
18 replies so far
#1 posted 11-24-2009 01:17 AM |
What do you mean by no power. Does the motor stop? Slow down? Does it burn the wood? How big is the motor Horse Power wise? 110 volt or 220 volt? -- Max "Desperado", Salt Lake City, UT |
#2 posted 11-24-2009 04:19 AM |
It depends on the motor type. AC induction motors don’t have bushes but AC universal motors do. If it’s a capacitive start/capacitive run motor the run capacitor could be bad. Post the motor nameplate data or a picture of the nameplate if you can. And a picture of the motor and saw and the Delta part number for the saw. -- -Curt, Milwaukee, WI |
#3 posted 11-24-2009 05:08 AM |
I had a capacitor go bad on a Delta saw several years ago and it was doing the same thing as the op said his was doing. I put a new capacitor on it and it was back to normal again. I also had a capacitor go bad on another Delta and it wouldn’t start and needed a new capacitor. I had a 3 hp dust collector wouldn’t start and it was a capacitor also. I ordered the capacitors from MSC in Atlanta for half what Delta wanted from them. BlankMan could be right about your saw. -- Bruce Free Plans http://plans.sawmillvalley.org |
#4 posted 11-24-2009 09:03 AM |
I should have mentioned, if the motor has two humps on it (the housings for the capacitors) then it’s most likely a capacitor start/capacitor run motor and the symptoms you’re describing sound like the run capacitor failed. It could also be the centrifugal switch, depending on the design and if they just cut out the start capacitor (SPST switch) or if they switch from the start capacitor to the run capacitor (SPDT switch). If the motor only has one hump then it’s most likely a capacitor start/induction run motor, if the single capacitor were bad on that motor it most likely would not spin up and/or growl when you turned it on. Had one do that when the centrifugal switch failed to close on spin down. Delta used to use Baldor capacitor start/capacitor run motors on their UniSaws, that’s what mine has, it has the two humps. They may have used them on other saws too. Don’t know if they still use them though. Capacitor start/capacitor run motors are more expensive but they are more efficient using less power, run smooth and have less vibration and run cooler. -- -Curt, Milwaukee, WI |
#5 posted 11-24-2009 08:33 PM |
If the motor runs, make sure the belts are tight. ( Not while the motor is running—Goes without saying, but I’ve heard of dumber things being done) They could be slipping, which would cause a loss of power to the blade. |
#6 posted 11-25-2009 01:16 AM |
the saw blade slows down then stops, but the motor keeps running. it s 120 volts, 15 amps, 25-60hz. yall are great cant believe the number of replys. |
#7 posted 11-25-2009 01:21 AM |
Check to make sure it’s wired right. Wiring the motor for 240 will cause it to work on 120 but have no balls (slow/stall when the wood hits it) |
#8 posted 11-25-2009 01:22 AM |
Needs a new belt most likely. If the motor still runs but the blade stops. |
#9 posted 11-25-2009 01:27 AM |
If the saw was starved. i.e. it was run using a small extension cord and some hard cutting was tried then it could have burned windings on the rotor. When this happens the saw will become weak. Aren’t the capacitors mainly needed for the motor to get up to speed only when started? -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. |
#10 posted 11-25-2009 02:07 AM |
34-670 looks to be a universal motor, no capacitors, so I’d check the brushes to start off with. No external belt, one internal belt in under the end bell. Looks to be a timing belt. I’d check that out too, if the teeth on belt stripped off that would explain it. No tension adjustment so if it stretched and it’s lose thus causing slippage it would need to be replaced. I’d take the motor apart and check out the commutator (where the brushes ride on) and clean it. Material build up between the copper bars on the commutator can short the windings causing a loss of power. And use emery cloth to clean the copper bars back to a nice shine. But if you say the blade slows down and/or stops and the motor keeps spinning I highly suspect that belt. (I’m assuming the blade is tight on the arbor and that’s not the cause.) -- -Curt, Milwaukee, WI |
#11 posted 11-25-2009 03:04 AM |
so i should pull the motor, unbolt it . pull apart the hub/ whatever its called on the end the brushes are located. does it matter which way faces up?,or do it level. dont want stuff falling out on me. then check the belt. if looks good clean the commutator. i will check brushes first, but if look good dont want to have a bunch of parts on my hands. |
#12 posted 11-25-2009 03:23 AM |
Here’s a link to an exploded view of the motor, it doesn’t look to bad to disassemble. The belt is item 226 and it looks easy enough to get the cover over it off. If you do take it further apart to clean the commutator remove the brushes first, that’s probably the only thing that might pop out. Looks like it might or might not be easy to take it apart to get at the commutator. If the bearings on the shafts are pressed on the shafts and into the housing that would be the might not. But if they do slide out that would be the might. I’d take the the screws out and if it comes apart without force then ok, but I wouldn’t force it. If you’re not mechanically inclined (no offense) and not comfortable with disassembling it see if there’s somebody that would help you or do it for you. Looking at the picture again you might have to remove the pulley to split the case and that looks held on by a clip ring. Not a show stopper. -- -Curt, Milwaukee, WI |
#13 posted 11-25-2009 03:11 PM |
Oh, its one of THOSE saws. Those belts shear pretty easily as they age. Sheared cogs would allow the assembly to run fine with no load and slip as soon as load ate up the inertia. |
#14 posted 11-25-2009 03:20 PM |
Sounds like a dehydrated Squirrel to me. Give him some gatorade. - Just kidding - |
#15 posted 11-26-2009 05:06 PM |
Check things in order before tearing it apart. -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! Variety is the Spice of Life!! |
Forum | Topics |
Woodworking Skill Share
12031 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4905 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1419 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
