Routing a profile on an irregular shaped work piece.
Forum topic by dbhost posted 11-23-2009 07:07 PM 1502 views 0 times favorited 8 replies Add to Favorites Watch
View dbhost's profile
dbhost
5708 posts in 3225 days
11-23-2009 07:07 PM
Topic tags/keywords: question
For our upcoming (before Christmas) Anniversary present this year, I wanted to make something special for LOML… I have decided on a heart shaped candle holder to hold the wedding candles from our wedding.
The material chosen is a piece of 3/4” pine, sourced from the building we had the reception in. (It suffered damage during Ike, and has been rebuilt since).
I have the heart shape cut out, and sanded, I am planning on adding pre made turned holders sized for the candles. they will be glued into the heart and act as uprights.
I would like to route a profile around the heart, but want to make sure that I don’t have any blow out.
I want to do a simple 3/8” roundover.
Any suggestions would be greatly appreciated.
8 replies so far
View Jim Bertelson's profile
Jim Bertelson
4170 posts in 3157 days
#1 posted 11-23-2009 07:38 PM
Do you have any scraps or discards of the wood? Try it on that, it may not be an issue…......
-- Jim, Anchorage Alaska
Jim Bertelson
#2 posted 11-23-2009 07:40 PM
Or nibble away with a 1/4”, then increase to 3/8”.................
View EdWood's profile
EdWood
12 posts in 3307 days
#3 posted 11-23-2009 07:55 PM
I do this all the time on my router table with a round over bit with a guide bearing. I use a gripper pad and work the piece past the bit. The bearing keep everything under control and takes a fairly light pass.
-- Edwood - http://edwoodcrafting.blogspot.com/
16274 posts in 4211 days
#4 posted 11-23-2009 08:00 PM
Like EdWood said, this is a pretty straightforward procedure.
Will you be doing it freehand or on a router table? Either way, you may want to do it in a couple of passes to minimize tearout. If you do it on a table, just make sure to keep rotating the workpiece so that you are always feeding it as close as possible to 90 degrees to the cutting edge.
dbhost
#5 posted 11-23-2009 08:03 PM
On a router table. Specifically on the router insert of my BT… And yeah, I was planning on taking a couple of passes on it, No need to dive straight into the bit, yet.
Jim Bertelson
#6 posted 11-23-2009 09:23 PM
As per Charlie, on the router table, I did this recently on some oak ply, which is very subject to tear out, and had no problem. A push block with a cut out, comes to mind, which is very irregular, and no tear out anywhere. Again, using a guide bearing on a round over bit. Unless there is something crazy about that piece of wood, hence the suggestion about trying on a piece of scrap.
dbhost
#7 posted 11-23-2009 10:10 PM
No problem with the bearing guided round over. Have them to spare…
I get to get busy tonight I guess…
I have a few other projects that are in the “Finished, but not photographed” status that I am pending on posting about… You know how it is on LJs, no pics, didn’t happen…
But as a primer for that, keep your eyes peeled for posts RE: Band Saw Dust collection modifications, Kitty Condo, and on a non woodworking note, truck mods including DWV Intake mod, SCT tuner and refreshing the K&N filter… Hey, the truck is a tool too! Yes I did get HP gains, but that was not my primary goal, my primary goal with MPG gains…
Jim Bertelson
#8 posted 11-23-2009 11:07 PM
Oh, and while I am thinking of it, like Ed noted, use a gripper pad, or if it is too small for that, consider drilling a hole in it and attaching a temporary handle. I bet one of those bench cookies would work well too.
Got to thinking about safety on the router table when I was making my push block, seemed my fingers were getting close to that bit, so I adjusted and used a gripper of some sort, don’t remember what. And then bought a router book to study up on the safety aspect.
