Question on compound circle cutting
Forum topic by gavia111 posted 09-21-2015 10:37 PM 691 views 0 times favorited 3 replies Add to Favorites Watch
View gavia111's profile
gavia111
1 post in 975 days
09-21-2015 10:37 PM
Topic tags/keywords: how to router circle bevel question
I’ve been woodworking for years and for some reason can’t figure out the best way to make a specific cut. I need to cut an inner circle at 16” in diameter. This would normally be pretty easy, usually I’d build/use a circle jig on my router with a straight bit. But, the challenge is I need to bevel that cut 45 degrees. This is going to be done in 3/4” material.
I just can’t figure out the best way to get this done with precision. Any ideas? Thanks in advance.
3 replies so far
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1571 days
#1 posted 09-21-2015 10:49 PM
Have a band saw with that much throat?them tilt the table and make your circle with a jig.Or most jig saws can tilt 45 make a jig like the one for your router.
View Daruc's profile
Daruc
460 posts in 1129 days
#2 posted 09-21-2015 11:09 PM
Cut a circle as you normally would to use for a template
Put the template on the pc you need and cut another circle with your straight bit with the bearing on, riding the template.
Then, without removing the template, Get a 45 deg. champher bit with a bearing and run it around the hole.
The only thing is the 45 deg champher bit will have to be pretty big, like this.
View pintodeluxe's profile
pintodeluxe
5657 posts in 2809 days
#3 posted 09-22-2015 12:14 AM
One of my old Bosch routers (an old version of the colt) has a tilting base.
I think I like Woodust’s idea better.
