How are these legs cut?
Forum topic by missesalot posted 09-21-2015 05:54 PM 1692 views 0 times favorited 33 replies Add to Favorites Watch
View missesalot's profile
missesalot
102 posts in 1840 days
09-21-2015 05:54 PM
Can someone explain to me how the legs on this are done? This pic is an extreme example, but figured the feature is obvious in this pic (is this called reverse taper?) how would these be cut? Could it be done with hand tools? Is there a particular style this is indicative of?
33 replies so far
View ChefHDAN's profile
ChefHDAN
1231 posts in 3091 days
#1 posted 09-21-2015 06:15 PM
no pic
View CharlesA's profile
CharlesA
3361 posts in 2039 days
#2 posted 09-21-2015 07:10 PM
Scroll saw and a dead blow mallet.
View AlaskaGuy's profile
AlaskaGuy
5002 posts in 2550 days
#3 posted 09-21-2015 07:26 PM
No picture
View JayT's profile (online now)
JayT
6017 posts in 2452 days
#4 posted 09-21-2015 07:31 PM
I’d cut those with a super light “Airweight” hand saw—the kerf is so thin you can’t even see it. This looks like one of those projects that doing it with hand tools is just as fast as power tools and gives identical results. :-)
-- In theory, there is no difference between theory and practice. In practice, there is.
View Ocelot's profile
Ocelot
2127 posts in 2879 days
#5 posted 09-21-2015 07:33 PM
missesalot? Hmm nice name! :-)
missesalot
#6 posted 09-21-2015 07:35 PM
yup, i deserved all that:-) pic added
View Shadowrider's profile
Shadowrider
183 posts in 1451 days
#7 posted 09-21-2015 07:43 PM
Large commercial planer with a sled of some sort?
View ShaneA's profile
ShaneA
7064 posts in 2840 days
#8 posted 09-21-2015 07:47 PM
It could be done with a band saw for sure. There would be some cleanup, but that would be my first choice. I am sure you could get there with hand tools, and maybe a table saw too…depending on the thickness of the legs.
CharlesA
#9 posted 09-21-2015 07:48 PM
You could adapt Chuck Bender's method tapered legs on a jointer. The other method would be on a bandsaw—you would need to tape on the cut off to make it square for at least one side. You’d have more clean up to do on the bandsaw.
View Grumpymike's profile
Grumpymike
2356 posts in 2557 days
#10 posted 09-21-2015 07:54 PM
Same as putting a taper on a smaller leg, Taper the two insides and leave the outsides straight.
You can use a taper jig or draw a line and run it through the band saw and clean up on the jointer.
If you look at them they are the same legs you’ve made hundreds of times and installed up side down.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View Daruc's profile
Daruc
460 posts in 1374 days
#11 posted 09-21-2015 08:03 PM
Cut 4 pcs, taper them, then bevel the 2 sides and glue together like a box.
View bearkatwood's profile
bearkatwood
1684 posts in 1253 days
#12 posted 09-21-2015 08:19 PM
Woodust has a good way if you are to laminate them, if you are using solid lumber mill up a square board and then make your tenon on the top smaller than the taper will go to. It is then just a simple four sided taper using a taper jig on a table saw and cauls to hold the work after the first sections have been cut away. This table has no skirt like a usual table, but has a picture style frame around it so the legs tenon would attach there. You can have a solid top and have the tenon come through the top for visible joinery work if you like. The style has an oriental feel to it. Here is a table we did with similar joinery, but a bit different leg and top with no frame.
-- Brian Noel
JayT
#13 posted 09-21-2015 08:35 PM
I agree with GrumpyMike about just the insides being tapered and with bearkat about doing the tenons before tapering. Many ways to taper legs that have been mentioned—table saw, band saw, jointer. I tapered the legs on my last project with a hand plane. Pick the method you feel most comfortable with.
View pintodeluxe's profile
pintodeluxe
5820 posts in 3055 days
#14 posted 09-21-2015 10:00 PM
1+ Woodust if hollow legs. Like that but with a locking miter bit at the router table.
If solid legs, then it depends on the capacity of your machinery. My first choice would be a taper sled at the tablesaw (save your offcuts!). With a 10” blade you are limited to 3” depth of cut.
Second choice would be bandsaw sled, then clean up the rough cuts with a light pass on the jointer.
I have seen jointer techniques to taper legs, but personally they give me the chills.
If you taper only the outside two edges, you will still have a vertical leg surface to make typical joinery such as horizontal rails.
Good luck with it. Stay safe.
View cabmaker's profile
cabmaker
1744 posts in 3050 days
#15 posted 09-22-2015 02:26 AM
Jointer would be my first choice. Very quick and efficient
showing 1 through 15 of 33 replies
