Beginner Lathe?
« back to Woodturning forum
Forum topic by esmthin posted 09-21-2015 04:50 AM 4051 views 0 times favorited 22 replies Add to Favorites Watch
View esmthin's profile
esmthin
77 posts in 1090 days
09-21-2015 04:50 AM
Topic tags/keywords: lathe turning
I have the opportunity to get several turning tools in a nice cabinet from an old woodworker who is starting to pack up shop. That’s an awesome steal, but there’s one problem, I don’t have a lathe. I’ve been browsing around online and my top choices so far are between the Grizzly H8259, $265 shipped, and the G0624, $338 shipped. I wouldn’t be doing anything huge, just pens, small bowls, and other little pieces. So, has anyone had any experience with either of these lathes, and would one would you recommend, or should I get a different brand? I don’t want to spend more than $400.
-- Ethan, https://instagram.com/ethan_woodworker/
22 replies so far
View Woodmaster1's profile (online now)
Woodmaster1
894 posts in 2496 days
#1 posted 09-21-2015 10:32 AM
Get the 12×18 lathe it has a bigger motor and variable speed. You will like the bigger motor and variable speed and it is in your budget.
View Arlin Eastman's profile
Arlin Eastman
4100 posts in 2470 days
#2 posted 09-21-2015 07:11 PM
Ethan
I would highly recommend this one of which I started out with.
https://www.pennstateind.com/store/TCLC12VS.html
also if you wish later it has a bed extension.
-- Please help me help other Vets click..> http://www.gofundme.com/m1abko.....It is always the right time, to do the right thing.
View DrDirt's profile
DrDirt
4421 posts in 3651 days
#3 posted 09-21-2015 09:51 PM
Definitely one with variable speed knob. moving belts around sucks.
esmthin
#4 posted 09-21-2015 11:51 PM
Arlin
I’m actually seeing that lathe listed at $450, which is more than I really wanted to spend and after reading some reviews it seems like the variable speed control is not very reliable. Thank you for the recommendation though.
View Bruyet's profile
Bruyet
40 posts in 1052 days
#5 posted 09-21-2015 11:59 PM
I started with the same one Arlin did, the PSI 12”. It was a great starter lathe. I never had a problem with the speed control. I sold it to get bigger and more powerful with a Nova 1624, but more importantly to get reverse speed. My Nova doesn’t have electronic variable speeds. Changing belt speeds is no big deal. No reverse speed is a deal breaker for me.
View jeff's profile
jeff
1063 posts in 3374 days
#6 posted 09-22-2015 12:04 AM
Variable speed for sure,belts are not fun to change.I have the Grizzly 0658 lathe which is now discontinued and I have been happy with this Grizzly purchase.How about the Grizzly model T-25920.More hp and variable speed.Don’t forget you will need a way to sharpen those tools.Good luck.
-- Jeff,Tucson,Az.
View SignWave's profile
SignWave
440 posts in 2944 days
#7 posted 09-22-2015 12:28 AM
Regarding the Grizzly H8259, there are a bunch of other brands that offer what sure seems like the same lathe (but in different colors). It’s a fine starter lathe, although I agree that variable speed would be nice. I got the Rockler version, which is often on sale for 199. If you have a HF local to you, you can try to use the 20% off coupon and get their version for 160 (they have it on sale for 199.99.)
If you want something new (vs. shopping around for something used), then this is a fine lathe to start with.
In the future, I can see getting something bigger with variable speed, reverse, etc. but still keep the small one around for smaller projects.
You might look at what type centers and/or chucks you’d be getting. These little lathes have MT2 tapers for the center and a 1”-8 thread for the chuck. If that isn’t what you’re getting from the other woodworker, then you might need to look at a different lathe.
-- Barry, http://BarrysWorkshop.com/
esmthin
#8 posted 09-22-2015 12:49 AM
Variable speed for sure,belts are not fun to change.I have the Grizzly 0658 lathe which is now discontinued and I have been happy with this Grizzly purchase.How about the Grizzly model T-25920.More hp and variable speed.Don t forget you will need a way to sharpen those tools.Good luck.
- jeff
The T-25920 is now my top choice after weighing it against the others. I like having the centers higher above the bed and more HP is always better. As for sharpening, could I just use diamond stones? I definitely don’t have the money to spend on a Tormek right now.
View David Taylor's profile
David Taylor
326 posts in 996 days
#9 posted 09-22-2015 01:42 AM
You don’t need a Tormek, just a grinder with decent wheels. One of these is fine, and can be had for $140, sometimes on sale for $100 – http://www.woodcraft.com/product/158512/rikon-8in-slow-speed-grinder.aspx
-- Learn Relentlessly
View TheDane's profile
TheDane
5367 posts in 3572 days
#10 posted 09-22-2015 01:46 AM
I definitely don t have the money to spend on a Tormek right now.
A Tormek would be my last choice for sharpening turning tools. For under $150 you can pick up a slow-speed grinder with friable wheels.
esmthin
#11 posted 09-22-2015 01:57 AM
Could I do it with stones though? After buying a lathe I won’t have the funds to get a grinder for a while.
TheDane
#12 posted 09-22-2015 02:15 AM
I suppose you could … depends on how much patience you have. You need to be able to sharpen proficiently … otherwise turning just won’t be much fun.
View MrUnix's profile
MrUnix
6373 posts in 2108 days
#13 posted 09-22-2015 02:16 AM
Could I do it with stones though? After buying a lathe I won t have the funds to get a grinder for a while.
Got a belt sander?
PS: If you are not dead set on buying new, you can get a LOT of lathe (or even a couple of them) for $400.
esmthin
#14 posted 09-22-2015 02:38 AM
Got a belt sander?
- MrUnix
I don’t have a belt sander, but even if I did, do the belts come in high enough grits?
I’ve been looking on Craigslist for quite a while now and haven’t seen any lathe other than the cheap single-bar Craftsmans.
View Woodknack's profile
Woodknack
11145 posts in 2289 days
#15 posted 09-22-2015 02:44 AM
- esmthin
It’s a better choice than the 10” models, based on features.
- esmthin
You can, it’s just that in turning you sharpen frequently.
-- http://thewoodknack.blogspot.com/
